Home > Off Topic > Cutting oil |
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4646 |
I know cutting oil must be specifically formulated for the job but if I wanted to drill into a Defender bumper and had no cutting oil to hand would engine oil or gear oil do as a substitute? 1982 88" 2.25 diesel
9th Jun 2020 4:17pm |
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4206 |
I don’t know about gear or engine oil, but WD40 works ok in a pinch. 2007 110 TDCi Station Wagon XS
9th Jun 2020 4:24pm |
Thank you. Like everyone else I would have some WD40 handy. 1982 88" 2.25 diesel
9th Jun 2020 4:26pm |
ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1777 |
engine oil or gear oil works well for hand drilling or pillar drilling in an old fashioned oil can...
HTH Keith |
9th Jun 2020 4:38pm |
And like WD40 I do have engine oil and gear oil to hand..... 1982 88" 2.25 diesel
9th Jun 2020 4:52pm |
Eh, just out of curiosity of course. If cutting all were needed in an emergency, I am told Anne Summers stock "lubricating oil". Would that do? And no, unlike WD40, engine oil and gear oil I do not have that on my work bench.. 1982 88" 2.25 diesel
9th Jun 2020 5:13pm |
williamthedog Member Since: 29 Dec 2012 Location: south wales Posts: 3441 |
^^ that's a bit of a waste isn't it?
9th Jun 2020 6:14pm |
The Anne Summers stuff is supposed to aid penetration...….. 1982 88" 2.25 diesel
9th Jun 2020 6:42pm |
It would be OK at the front for spotlights.
For a tow bar you'd need booty lube....... |
9th Jun 2020 6:51pm |
Does the Anne Summers website have user reviews like Screwfix? 1982 88" 2.25 diesel
9th Jun 2020 6:55pm |
Probably - dare you to leave one stating how easy it made drilling and screwing on your defender.......
9th Jun 2020 7:11pm |
sako243 Member Since: 08 Jul 2014 Location: Wales Posts: 1218 |
Given I drilled through my 12mm thick rear cross member with a 13mm drill with no lube I doubt you're going to need it
No pilot drill either, well it was sort it built in being a Dewalt Extreme 2 drill bit. Those things are great for thick steel! Ed 82 Hotspur Sandringham 6x6 95 Defender 110 300Tdi |
9th Jun 2020 8:21pm |
So no lube needed, just grind away...
Stop for a break now and then if things get hot? Better remember to tell the Mrs, "Don't touch that, it might be hot after all of that grinding". So after a short break I'll be ready to resume. As things will .have cooled down I'll be able to tell the Mrs, "Hold that while I get it centred". Oh and no hammer action, just a steady grind. Yep think I have it now. I'll let you know how I get on.... 1982 88" 2.25 diesel 1992 110 200tdi csw -Zikali 2008 110 2.4 tdci csw-Zulu 2011 110 2.4 tdci csw-Masai |
9th Jun 2020 8:37pm |
If you're still referring to drilling metal then if it's got hot you're done for. Ed
9th Jun 2020 8:50pm |
