Home > Off Topic > Cutting oil
spudfan
Ireland
Cutting oil
I know cutting oil must be specifically formulated for the job but if I wanted to drill into a Defender bumper and had no cutting oil to hand would engine oil or gear oil do as a substitute? 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #836148 9th Jun 2020 4:17pm
Bluest
I don’t know about gear or engine oil, but WD40 works ok in a pinch. 2007 110 TDCi Station Wagon XS
Post #836150 9th Jun 2020 4:24pm
spudfan
Ireland
Thank you. Like everyone else I would have some WD40 handy. Thumbs Up 1982 88" 2.25 diesel
Post #836151 9th Jun 2020 4:26pm
ickle
engine oil or gear oil works well for hand drilling or pillar drilling in an old fashioned oil can...
HTH Keith
Post #836154 9th Jun 2020 4:38pm
spudfan
Ireland
And like WD40 I do have engine oil and gear oil to hand..... Thumbs Up 1982 88" 2.25 diesel
Post #836162 9th Jun 2020 4:52pm
You're very unlikely to need cutting oil at all on something as insubstantial as a front bumper, but as above there are many substitutes which can be used if you want.
Post #836169 9th Jun 2020 5:07pm
spudfan
Ireland
Eh, just out of curiosity of course. If cutting all were needed in an emergency, I am told Anne Summers stock "lubricating oil". Would that do? And no, unlike WD40, engine oil and gear oil I do not have that on my work bench.. 1982 88" 2.25 diesel
Post #836171 9th Jun 2020 5:13pm
williamthedog
^^ Rolling with laughter that's a bit of a waste isn't it?
Post #836185 9th Jun 2020 6:14pm
spudfan
Ireland
The Anne Summers stuff is supposed to aid penetration...….. 1982 88" 2.25 diesel
Post #836191 9th Jun 2020 6:42pm
ickle
It would be OK at the front for spotlights.
For a tow bar you'd need booty lube.......
Post #836196 9th Jun 2020 6:51pm
spudfan
Ireland
Does the Anne Summers website have user reviews like Screwfix? 1982 88" 2.25 diesel
Post #836197 9th Jun 2020 6:55pm
ickle
Probably - dare you to leave one stating how easy it made drilling and screwing on your defender.......
Post #836200 9th Jun 2020 7:11pm
sako243
Given I drilled through my 12mm thick rear cross member with a 13mm drill with no lube I doubt you're going to need it Laughing
No pilot drill either, well it was sort it built in being a Dewalt Extreme 2 drill bit. Those things are great for thick steel! Ed
82 Hotspur Sandringham 6x6
95 Defender 110 300Tdi
Post #836220 9th Jun 2020 8:21pm
spudfan
Ireland
So no lube needed, just grind away... Whistle
Stop for a break now and then if things get hot?
Better remember to tell the Mrs, "Don't touch that, it might be hot after all of that grinding".
So after a short break I'll be ready to resume. As things will .have cooled down I'll be able to tell the Mrs, "Hold that while I get it centred". Oh and no hammer action, just a steady grind. Yep think I have it now. I'll let you know how I get on.... 1982 88" 2.25 diesel
Post #836233 9th Jun 2020 8:37pm
sako243
If you're still referring to drilling metal then if it's got hot you're done for. Ed
Post #836237 9th Jun 2020 8:50pm
