Home > Puma (Tdci) > Key Fob repair, 2014-16 type
DSC-off
Hi all,
Has anyone got a part number or know a source for a repair kit for this type of remote fob please?
It's the case I need, to fit the old circuit board into.
I've done a search and there are loads for various "5 button" types for around £12, but the unlock button is in the wrong place.
Cheers.
Post #834480 31st May 2020 9:46pm
The Zee
United Kingdom 2014 Defender 110 Puma 2.2 USW Indus Silver
I had a similar issue; my fob, same style as the above images (2 button with chrome slide) the rear panel had stared to disintegrate and the chrome slide had numerous dents and scratches in it.
The helpful local dealer (Hendy in Salisbury) were able to find the rear cover and sealing gasket by using them from a LR078922 kit (~£9.50+VAT) that contains the 5 button face as well, the sealing gasket & rear plate (Glossy with a sliver LR logo Smile ) fit the 2 button fob.
The reason I had to cannibalise the kit was that the 2 Button face is no longer available according to the dealership on it’s own only as a complete. The chrome slide is about £55 + VAT from memory. Shocked
I later required a third key and as a complete item it is available, front, back, gasket, chrome, circuit board and battery, as a complete without programming it’s £121 + VAT (OUCH) and needs to be pre ordered from LR Big Cry Zaid-M
www.DefencePhotos.com
2014 Defender 110 Utility, 2.2 Puma, Indus Silver
Not just transport more like a religion
Post #834484 31st May 2020 10:12pm
DSC-off
Thanks, that seems to confirm my fear that the 2 button case isn't available as a repair kit. Sad
They're obviously not very durable, and it doesn't look good for long term if they need regular replacement.
Nice one Landrover.
Post #834486 31st May 2020 10:39pm
mptzs90
United Kingdom 2015 Defender 90 Puma 2.2 XS CSW Corris Grey
Post #1060550 14th Feb 2025 3:39pm
Macleaa
Scotland 2015 Defender 90 Puma 2.2 SW Scotia Grey
https://www.eurocarkeyshop.com/lan110b-lan...a-defender
ive recently bought two of these key casings. They are fine except there are two small pins on which the internal pcb is mounted. These pins came out still attached to the pcb when it was removed from the old shell. As such I couldnt get the pcb to sit properly within the new key casing.
I just broke the pins off on the new shell and fitted in the new pcb. The pcb is effectively ‘loose’ within the shell but doesnt have room to move as such. The buttons align and it works just fine.
Post #1060598 15th Feb 2025 1:26am
Julie
Re: Key Fob repair, 2014-16 type
DSC-off wrote:
Hi all,
Cheers.
https://www.ebay.fr/itm/314658876019
Post #1060978 20th Feb 2025 1:52pm
Ianh
That’s for the Lucas fobs, not the Lear fobs for the 2014-2016 defender.
Post #1060979 20th Feb 2025 2:39pm
NickMc
As I said in a post about these a few weeks ago I’m pretty sure Ian at IRB developments does these and maybe BAS too.
Post #1061010 20th Feb 2025 10:03pm
Dasher
2015 Defender 110 Puma 2.2 USW Santorini Black
Julie wrote:
DSC-off wrote:
Hi all,
Cheers.
I've used the 5 button type as a replacement. The 'unlock' button lines up under the 'light' button. I blacked out the two right hand buttons and a bit of the 'light' that is now 'unlock' with a Sharpie. You can just ignore the hazard fifth button as it isn't easy to see anyway. Go easy when lifting out the pcb from the old fob. There are YouTube vids of the replacement. I used a genuine 5 button from a JLR dealer and it was under £20. Very happy, works well.
Post #1061561 27th Feb 2025 11:05pm
