![]() | Home > Technical > Identify Where this rubber moulding Goes! |
bear100 Member Since: 22 Mar 2010 Location: South Wales Posts: 1989 ![]() ![]() ![]() |
Looks like it grew there!
Let us know your findings ![]() 2016 Range Rover Autobiography 4.4 TDV8 (gone) 2010 110 XS Utility 2.4TDCI 2010 Range Rover Sport TDV8 (gone) 2007 Discovery HSE TDV6 (gone) 1993 110 csw 200 tdi (gone) 1994 90 HT 300 tdi (gone) 1994 discovery 300tdi (gone) 90 hybrid 3.5 v8 (gone) Range rover bobtail 3.5 v8 (gone) |
Sulisuli Member Since: 30 Oct 2016 Location: South west Posts: 4801 ![]() ![]() ![]() |
Fitted my eBay purchased rubber strip today on mine and SWMBO defender, nice snug fit and less than a fiver to do both defenders
![]() 2008 SVX 90 2000 XS TD5 90 |
Pacha Member Since: 23 Feb 2020 Location: North Yorkshire Posts: 781 ![]() ![]() ![]() |
Not done it yet, but I will seal it to the bulkhead. Initial impressions are it's better than nothing (currently). Rgds. Chris |
nitram17 Member Since: 09 Jun 2014 Location: newcastle Posts: 2261 ![]() |
Lots of defender owners are happy to be taken for a ride price wise for parts.......... but that lr bespoke piece of rubber does stop a lot of water from water flooding the footwell......... the stuff you have sourced looks a decent enough replacement!
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2278 ![]() ![]() |
The OEM rubber fits so it’s inner edge covers the bolt head that’s gone rusty and is tight to the bulkhead . No doubt water has been saturating that bolt due to the missing rubber, hence its condition. Mines fine yet I’ve still given that bolt a good soaking with acf50. But also considering some silicon to make a proper seal to the bulkhead. Noting you need to use the correct silicon as general building / bathroom silicon eats into metal as it’s acidic. The stuff they use on windscreens is good and does not set hard so easy to remove and reseal after if needed. |
Thanks Ian - I will be using the Flexi car body work stuff. Rgds.
Chris |
JoolsB Member Since: 28 Mar 2020 Location: The North Posts: 167 ![]() ![]() ![]() |
Used some silkoline on mine and now it’s leak free...well except when I park with the N/S/F wheel as the lowest point...so I don’t,
