![]() | Home > Td5 > Hawkeye 11 Air flow KG/hr |
davidblythe Member Since: 27 Apr 2019 Location: Cheam, Surrey Posts: 110 ![]() ![]() |
Have a 10p td5 and a 15p td5, both have the egr disconnected
Using Live data on the Hawkeye, the 15p engine shows a default setting (I Believe) of 4.4kg/hr when stationery and does not change when driving the 10p engine shows a vaue of 0 both stationery and driving (this has a 15p ecu fitted) anyone know what these values refer to and do i have a problem (engines run fine) |
thank you
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6163 ![]() ![]() ![]() |
I've had 4.4 readins as well... the engine had felt a bit flat for a while.
Changed the MAF and whoosh! it flew afterwards! |
TD5Neil Member Since: 02 Nov 2017 Location: Cambridgeshire Posts: 42 ![]() ![]() |
It’s a common MAF failure to just show a constant 4.4. Mine was like this when I checked with a Nanocom. I always thought it drove well despite the MAF. Duckworth parts do a good discount on the genuine sensor.
