Home > Td5 > JE Engineering stage 1 tune |
I think most tunes will give a small amount off black smoke below rougly 2000 rpm, above that there should not be any black smoke in my eyes. Roel
6th May 2020 4:58pm |
CarMan Member Since: 29 Nov 2010 Location: Cotswolds Posts: 1865 |
I had one a few years back and no smoke, but it did add more go, though I felt that perhaps it came in a little suddenly Rob
1993 200tdi 90 hard-top 1998 300tdi 90 soft-top 2016 2.2 XS 90 hard-top (sold) |
6th May 2020 5:13pm |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8077 |
I had one in 99 on my td5, je stage 1, loved it no smoke good economy over the 97k miles I had it. Went back to them for my l322. Cheers
6th May 2020 5:20pm |
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2185 |
Stages are .
Just have your car tuned to what you want it to do. Speak to Gareth at Empire he is ex JE. Brilliant guy and knows it all. Instagram @defender_ventures Empire Tuning - Agent |
6th May 2020 6:49pm |
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7907 |
As above, I'd speak with forum sponsor Gareth at Empire Tuning! Does great work!! Will tune to suit your exact requirements, not just a standard tune. James
MY2012 110 2.2TDCi XS SW Orkney Grey - http://www.defender2.net/forum/topic43410.html MY1990 110 200TDi SW beautifully faded Portofino Red - https://www.defender2.net/forum/post743641.html#743641 MY1984 90 V8 Slate Grey - https://www.defender2.net/forum/post744557.html#744557 Instagram @suffolk_rovers |
6th May 2020 7:10pm |
Landlord Member Since: 27 Oct 2009 Location: Hampshire Posts: 582 |
Have one on my 90. Done 11 years ago - can't fault it - great remap 2007 TD5 90 Hard Top |
7th May 2020 2:54pm |
90GTR Member Since: 05 May 2020 Location: London Posts: 201 |
Great to hear it, will likely be sending it down when lockdown eases off.
For the moment I don't really need something specific to my use. Its more of case of just waking it up a bit more ! It already feels better with the new air sensor! Whats the feeling regarding additional wear on the turbo / other components? Think this truck has about 108k.... |
7th May 2020 9:27pm |
Was my post removed ref empire? Cheers
7th May 2020 9:39pm |
keith Member Since: 15 Aug 2012 Location: Edinburgh Posts: 2217 |
Yes JE did my tune on TD5 2006. Had the roof tent on at the time and when he took it for a test drive, approaching the roundabout way too fast, nearly rolled it. Big fright to us both.
7th May 2020 9:40pm |
Barely run in!!! Mines at 137k driven daily and putting out some chunky power at the min. Planning to go further shortly. That said I had the turbo off and fitted a hybrid within 2 days of getting my 110 easy to check wear on the turbo just pull the hose off anf give it a wiggle. Minimal lateral play is fine in and out play is not. Click image to enlarge TD5s are wonderful engines, very strong, very powerful (when done right) and very reliable. Gareth at Empire would run through everything with you, along with check the car over to ensure its healthy enough to take it. Post lockdow that is! Best bet is to speak to him. Instagram @defender_ventures Empire Tuning - Agent |
7th May 2020 10:18pm |
Around 1 year After my TD5 JE tune, I remember hearing a whistling noise when on throttle. Turned out to be cracked manifold, as a result of higher temperatures due to the tuneup. There’s always a negative somewhere along the line.
Keith |
12th May 2020 5:58pm |
Intercept Member Since: 27 Feb 2017 Location: Suffolk Posts: 587 |
I'd echo that. http://www.empiretuning.co.uk/ |
13th May 2020 10:18am |
Chris86 Member Since: 15 Jul 2014 Location: South Yorks Posts: 790 |
I was under the impressions that stages of tune are related to the physical modifications done/needed to run that particular software? Regards Chris |
13th May 2020 10:41am |
MGDM4 Member Since: 28 Aug 2015 Location: Leeds Posts: 45 |
Everyone has different definitions of 'Stage x' so even that is hard to compare like for like.
As mentioned previously remaps should definitely not be done in stages as they should be bespoke to the owners requirements and the vehicles modifications. |
17th Dec 2020 5:50pm |
