Home > In Car Electronics > Sealing AMP/Econoseal connectors
excossack
On my trailer I have a few of the AMP/Econoseal connectors for the lights. They have the rubber seal things that come with them.
I was thinking of adding extra protection to the cable inlets/outlets. So thought maybe a dab of RTC into each cable inlet/outlet? 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #828135 28th Apr 2020 7:41am
rallysteve
Not 100% but I think RTV will damage the pvc insulation on the cables. As long as they are properly crimped and assembled then they are pretty good for water resistance. It would be worth getting hold of some contralube (or similar) to keep moisture off the terminals though. I think pretty much all the Econoseals that I have witnessed having failed are due to corrosion of the cable/terminal at the point of the crimp.
Post #828139 28th Apr 2020 7:52am
Mo Murphy
I always put a smear of Vaseline on the terminals to try and prevent corrosion.
50 Shades of Pennine Grey
Post #828150 28th Apr 2020 8:32am
excossack
Cheers chaps, or maybe battery terminal smearing stuff? 1999 Defender TD5 110
Regards
John M0VAZ
Post #828158 28th Apr 2020 8:57am
Mo Murphy
I'm sure that would be fine.
I've only had problems with terminal corrosion on the rear indicators and fog/ reversing lights which are really exposed to the wet.
Post #828168 28th Apr 2020 9:41am
Martin
Site Admin
If assembled correctly they don't need any extra sealing. As above adding something extra is likely to be irregular and let water in.
Remember that the narrow part of the seal should be crimped inside the wider end part of the terminal, not just pushed in afterwards (as so many do).  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #828175 28th Apr 2020 9:57am
DuncanS
United Kingdom 2008 Defender 110 Puma 2.4 USW Santorini Black
If you have really exposed superseals (2 pin & 3 pin) I tend to use the rubber boots to go over the back of them which give a nice tight seal. I then use some amalgamating tape on each end of the boot to completely seal it, whilst still giving it some natural flexibility. Never had an issue using this method in the wheelarches of our two works ifor williams trailers. North Cumbria Search and Rescue - Team Leader
Post #828181 28th Apr 2020 10:04am
rallysteve
I am not sure I have ever seen a boot for Econoseal III (the most common type as used on Defender lights etc). I cant think how they would fit onto the shape of the connector, especially the Female half.
Are you sure you arn't thinking about Superseal 1.5series connectors?
Post #828188 28th Apr 2020 10:29am
The clue is in the name, EconoSEAL ! When assembled correctly they are sealed.
Post #828189 28th Apr 2020 10:32am
DuncanS
Sorry, yes you are correct I had intended to write superseal haha. Need more coffee!! You can use a 6/8pin Deutsch boot, but make sure its of the matt coloured bellows type, not the smooth plastic. North Cumbria Search and Rescue - Team Leader
Post #828190 28th Apr 2020 10:33am
excossack
I have crimped the rubber seal to the end of the pin (which I didn't know you needed to do until a YT video showed me)
I am using 4 pins ones on trailer lights. Also didn't know you could get boots. 1999 Defender TD5 110
Regards
John M0VAZ
Post #828191 28th Apr 2020 10:35am
excossack
I guess there is a clue there! 1999 Defender TD5 110
Regards
John M0VAZ
Post #828192 28th Apr 2020 10:36am
DuncanS
I don't think you'll neccessarily get one to fit over a 4 pin as they don't make them specifically for econoseal.
I personally hate econoseals with a passion and tend to go to a superseal for most hidden stuff. On my defender I'm currently using deutsch DT with the proper backshells (if onto conduit) or the shiny boots with glue shrink if onto harnesses. North Cumbria Search and Rescue - Team Leader
Post #828193 28th Apr 2020 10:40am
excossack
I ordered Tyco AMP connectors (same as EconoSeal?) 1999 Defender TD5 110
Regards
John M0VAZ
Post #828194 28th Apr 2020 10:43am
DuncanS
Send us a link to what you ordered. Tyco AMP I see most often used to refer to a superseal, although strictly its a brand name of TE Connectivity nowadays, and one of those connectors that has been copied hundreds of times. North Cumbria Search and Rescue - Team Leader
Post #828196 28th Apr 2020 10:48am
