![]() | Home > Technical > How does this grille attach? |
22900013A Member Since: 23 Dec 2010 Location: Oxfordshire Posts: 3150 ![]() ![]() ![]() |
What holds this grille on? Went to refit it after removing my RAI and there doesnt seem to be anything for the pins to grip on.
Any ideas? ![]() Click image to enlarge ![]() Click image to enlarge 2011 110 USW 1973 Series III 1-Ton 1972 Series III 1-Ton Cherrypicker 1969 IIA 1-Ton 1966 IIA 88" |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5822 ![]() ![]() |
The pins, as in the pins that snap off, the grill, go into the holes
Looks like I am indeed missing some small bushings that hold the grille on. I've ordered some so hopefully that will do the trick. 2011 110 USW
Ads90 Member Since: 16 Jun 2008 Location: Cots-on-the-Wolds Posts: 812 ![]() ![]() ![]() |
I don't think you are - think the plastic pins just push in the holes?
I found my vent hanging on by only a pin or two, as others had snapped - ordered a metal one and that had screws that went straight into the holes. |
Daisy90 Member Since: 01 Feb 2015 Location: Hampshire Posts: 845 ![]() ![]() ![]() |
As the weather / temp at urge is favorable why not use a suitable bondant ?
Avelingporter Member Since: 25 Jan 2016 Location: Southampton Posts: 406 ![]() ![]() ![]() |
I replaced mine ten days ago. Got the bits from Duckworths.
The grill has 5 pins on the back. Which snap off hence the replacement. The wing has small plastic bushes which fix into the wing. The grill is then a push fit into the bushes. |
Badger110 Member Since: 06 Feb 2018 Location: South hams Posts: 1039 ![]() ![]() ![]() |
Mine was stuck on...i say 'was' because it fell off some weeks ago
![]() Just got a hole now with some old silicone around it. There doesn't seem to be anywhere that a fixing was used. Which will explain why it fell off. |
macfrank Member Since: 05 Nov 2015 Location: somewhere in the north Posts: 1105 ![]() ![]() ![]() |
Same same but different, using the Mantec RAI's screw positons, so I could swap should the RAI fall off ![]() ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge |
