Home > Technical > How does this grille attach? |
22900013A Member Since: 23 Dec 2010 Location: Oxfordshire Posts: 3150 |
What holds this grille on? Went to refit it after removing my RAI and there doesnt seem to be anything for the pins to grip on.
Any ideas? Click image to enlarge Click image to enlarge 2011 110 USW 1973 Series III 1-Ton 1972 Series III 1-Ton Cherrypicker 1969 IIA 1-Ton 1966 IIA 88" |
24th Apr 2020 4:37pm |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5790 |
The pins, as in the pins that snap off, the grill, go into the holes
24th Apr 2020 4:49pm |
Looks like I am indeed missing some small bushings that hold the grille on. I've ordered some so hopefully that will do the trick. 2011 110 USW
24th Apr 2020 5:46pm |
Ads90 Member Since: 16 Jun 2008 Location: Cots-on-the-Wolds Posts: 812 |
I don't think you are - think the plastic pins just push in the holes?
I found my vent hanging on by only a pin or two, as others had snapped - ordered a metal one and that had screws that went straight into the holes. |
24th Apr 2020 6:39pm |
Daisy90 Member Since: 01 Feb 2015 Location: Hampshire Posts: 845 |
As the weather / temp at urge is favorable why not use a suitable bondant ?
24th Apr 2020 7:33pm |
Avelingporter Member Since: 25 Jan 2016 Location: Southampton Posts: 406 |
I replaced mine ten days ago. Got the bits from Duckworths.
The grill has 5 pins on the back. Which snap off hence the replacement. The wing has small plastic bushes which fix into the wing. The grill is then a push fit into the bushes. |
24th Apr 2020 7:46pm |
Badger110 Member Since: 06 Feb 2018 Location: South hams Posts: 1039 |
Mine was stuck on...i say 'was' because it fell off some weeks ago
Just got a hole now with some old silicone around it. There doesn't seem to be anywhere that a fixing was used. Which will explain why it fell off. |
24th Apr 2020 7:48pm |
25th Apr 2020 8:22am |
macfrank Member Since: 05 Nov 2015 Location: somewhere in the north Posts: 1083 |
Same same but different, using the Mantec RAI's screw positons, so I could swap should the RAI fall off Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge |
25th Apr 2020 7:12pm |
