![]() | Home > Puma (Tdci) > Immobiliser woes? Engine won't start - What should I check? |
Chopperone Member Since: 13 Nov 2016 Location: Derbyshire Posts: 396 ![]() ![]() |
Hi
Some advice please. I have a 2007 Tdci 2.4 with Central locking & two alarm fobs. The vehicle battery is 18 months old. Last week I went to move the vehicle which I hadn't used for about 3 weeks & it wouldn't start so I recharged battery & moved it out the garage - left it running for 5 mins & switched off to do my jobs. One of the jobs entailed disconnecting the battery for a few minutes. Once completed I went to start it & it wouldn't start & alarm sounded. Tried a number of times & I thought the battery had gone down again. I recharged it overnight. I also changed the battery in the alarm fob. The alarm fob does not unlock/lock the vehicle. The alarm/immobilise lights are not illuminated at all. So far I have tried pressing the fob repeatedly , I have disconnected battery & left off for 1/2hr. I have tried touching +ive to -ive terminals to "re-set" ; all to no avail. I have read through various posts here. I don't have a Nanocom. I have checked fuses & all appear to be in order. What's my next move please? Cheers Guy May your life be like toilet paper ; long & useful. |
Issue resolved !
Fuse 1 had blown & it blew again - not sure why. I replaced it & starting checking door switches. I then decided to RTFM & then applied some logic I have the alarm /immobiliser & C/L all working and the vehicle runs ![]() No where to go/not allowed to go anywhere. Still at least I can move it out of the yard. Stay safe folks Guy May your life be like toilet paper ; long & useful. |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8172 ![]() ![]() ![]() |
Top result. Cheers
Fuse 1 is ABS unit
![]() Last edited by dorsetsmith on 11th Apr 2020 5:23am. Edited 2 times in total |
Unfortunately l spoke too soon.
I replaced the 20 amp fuse in position 1 under the driver’s seat.( marked central locking). I have Mazda seats in my 90 so not exactly a 2 minute job to access the fuse box. Then reset alarm & tested - everything ok. Put seats back in / quick test & drove up my drive & then put back in garage; reset alarm & it popped the fuse,alarm goes off & it won’t start ![]() What l don’t understand is that l didn’t do anything anywhere near the C/L When l did the few jobs the other day. I can only assume that there is a short somewhere in the C/L circuit which is causing the problem. Any known areas where l should start looking? Thanks Guy May your life be like toilet paper ; long & useful. |
If it was cl surely it would just not lock that door with failed wiring. Cheers
You mean Fuse 7 feeds the battery voltage input pin 25 gray plug on the alarm unit
also feeds door locking output on the alarm unit green plug pin 3-2 Good place to start Central locking wiring ![]() Click image to enlarge Id start with door to a pliller rubber and wiring |
Thanks for everyones input so far.
I am confused about FUSE 7. I have 2 x fuse locations in my 2007 90. One under the steering column & one under the driver’s seat. Under the driver’s seat there is a 20 amp fuse in the first position ; it is marked C/L ( nothing else) this is the fuse that blows. There is no reference to fuse 7. What am l missing? I will have another good look in the next few days to try & solve this Thanks Guy May your life be like toilet paper ; long & useful. |
This will keep you busy
https://1drv.ms/b/s!AtZSoWFHDgnGkGkrFWcZsRtsH3Dp?e=5L8B2W https://1drv.ms/b/s!AtZSoWFHDgnGhDbxYedTopmyd1rA?e=a7MCOv Last edited by dorsetsmith on 12th Apr 2020 7:06am. Edited 1 time in total |
Hi
Thanks Dorset. I now understand It is Fuse 7 that blows. So l need to trace where the wiring goes to that fuse....... Thanks Guy May your life be like toilet paper ; long & useful. |
And just so you can find think from drawing
https://1drv.ms/b/s!AtZSoWFHDgnGjECIf_wOfqrjegKe?e=kEfY0P |
thompo Member Since: 26 Sep 2016 Location: stoke-on-trent Posts: 2 ![]() ![]() ![]() |
Hi everyone i had problems with central locking on my puma ;i replaced my radio and sorted central locking out broken wire in door pillow behind passenger seat i had dissconected the battery,but tried everything it would not start i called a man that can it took him five minutes .He took the key fob away from the vehicle removed the battery from it pressed the buttons on the fob a few times replaced the battery pointed it at the car locked and unlocked it jumped in and it started.i hope you find this of help.
Finchy13 Member Since: 07 Apr 2019 Location: North East Posts: 20 ![]() ![]() ![]() |
I had a similar problem when the battery died on my puma. Tried to start it after charging the battery but it wouldn't crank or lock/unlock from the fob. Had a blown fuse, can't remember which, replaced it and still no joy. Had to get a bloke out to reprogram the 10AS unit as its all too common for it to loose its coding...
Finchy - I had the same problem. Problem was I was in a psychiatric hospital car park and everything I tried set the alarm off. Eventually, I was politely asked to have it towed
![]() ![]() But shout it at them in German because life is also terrifying and confusing... |
