Home > Maintenance & Modifications > Filling in rivet holes
Page 1 of 3 123>
charcoal
United Kingdom 2005 Defender 110 Td5 HT Bonatti Grey
Im looking at buying a bonnet which came from factory with spare wheel carrier but it has had the carrier removed and chequer plate on to cover the holes. Does anyone have any suggestions on how to fill the rivet holes in the bonnet once the chequer plate is removed? 1999 Land Rover Defender 110 td5 station wagon
1998 Land Rover Defender 110 County Station Wagon ~ Sold
1995 Land Rover Defender 110 V8 Station Wagon ~ Sold Sad
1985 Land Rover 110 ex mod project Tithonus ~ Sold Sad
Post #822540 31st Mar 2020 7:10pm
ickle
Easiest would be short Adel pop rivets and paint over it is a Land Rover after all!
Otherwise countersink and set a soft alloy solid rivet in place, rub down and surface finish the top & paint.
HTH Keith
Post #822543 31st Mar 2020 7:20pm
charcoal
Thanks ickle the latter sounds like a good bet as it'll need painting anyway Thumbs Up 1999 Land Rover Defender 110 td5 station wagon
Post #822548 31st Mar 2020 7:34pm
TIG weld them. Have you seen the bonnet and holes? Most bonnet mounts also require some large holes so it may be more than just rivets.
Post #822549 31st Mar 2020 7:36pm
charcoal
Sorry I should've clarified, I want the one made to be fitted with a spare wheel carrier as I plan to fit one back to the bonnet so the holes for that are not a problem, just the tiny ones from the chequer plate as Id prefer the bonnet without it. 1999 Land Rover Defender 110 td5 station wagon
Post #822551 31st Mar 2020 7:41pm
Ah, sorry, I misunderstood, it's the chequerplate holes!
I'd still try to TIG weld then grind smooth.
Post #822558 31st Mar 2020 8:14pm
charcoal
That sounds a lot easier to be fair, will have to see about borrowing a welder then! 1999 Land Rover Defender 110 td5 station wagon
Post #822563 31st Mar 2020 8:21pm
A really low tech approach would be to glue (Sikaflex/Tigerseal) some small pieces of ali under each hole and then fill and paint. Darren
Post #822566 31st Mar 2020 8:23pm
charcoal
A very low tech aproach indeed, would there be the risk of them falling off with all the viabration and heating/cooling? 1999 Land Rover Defender 110 td5 station wagon
Post #822583 31st Mar 2020 8:56pm
No, shouldn't do with one of those sorts of adhesives. Darren
Post #822611 31st Mar 2020 9:45pm
charcoal
Cool will look into that also then when this new bonnet comes Thumbs Up 1999 Land Rover Defender 110 td5 station wagon
Post #822624 31st Mar 2020 10:24pm
Oldowner
Also known as a complete bodge.
Post #822646 1st Apr 2020 7:23am
Oldowner
This is how not to bodge it. Rear tub chequerplate removal.
Post #822647 1st Apr 2020 7:26am
VVS210
Or a perfectly functional bush fix for someone who has neither the kit to TIG weld themselves or the opportunity/funds to take it to someone to weld it for them Whistle
Post #822649 1st Apr 2020 7:35am
Thanks for that. Not everybody has access to a tig welder Rolling Eyes Darren
Post #822651 1st Apr 2020 8:03am
Page 1 of 3 123>
