Home > Maintenance & Modifications > Filling in rivet holes |
ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1786 |
Easiest would be short Adel pop rivets and paint over it is a Land Rover after all!
Otherwise countersink and set a soft alloy solid rivet in place, rub down and surface finish the top & paint. HTH Keith |
31st Mar 2020 6:20pm |
charcoal Member Since: 28 Jul 2014 Location: Hampshire Posts: 942 |
Thanks ickle the latter sounds like a good bet as it'll need painting anyway 1999 Land Rover Defender 110 td5 station wagon
1998 Land Rover Defender 110 County Station Wagon ~ Sold 1995 Land Rover Defender 110 V8 Station Wagon ~ Sold 1985 Land Rover 110 ex mod project Tithonus ~ Sold |
31st Mar 2020 6:34pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17453 |
TIG weld them. Have you seen the bonnet and holes? Most bonnet mounts also require some large holes so it may be more than just rivets.
31st Mar 2020 6:36pm |
Sorry I should've clarified, I want the one made to be fitted with a spare wheel carrier as I plan to fit one back to the bonnet so the holes for that are not a problem, just the tiny ones from the chequer plate as Id prefer the bonnet without it. 1999 Land Rover Defender 110 td5 station wagon
31st Mar 2020 6:41pm |
Ah, sorry, I misunderstood, it's the chequerplate holes!
I'd still try to TIG weld then grind smooth. |
31st Mar 2020 7:14pm |
That sounds a lot easier to be fair, will have to see about borrowing a welder then! 1999 Land Rover Defender 110 td5 station wagon
31st Mar 2020 7:21pm |
A really low tech approach would be to glue (Sikaflex/Tigerseal) some small pieces of ali under each hole and then fill and paint. Darren
31st Mar 2020 7:23pm |
A very low tech aproach indeed, would there be the risk of them falling off with all the viabration and heating/cooling? 1999 Land Rover Defender 110 td5 station wagon
31st Mar 2020 7:56pm |
No, shouldn't do with one of those sorts of adhesives. Darren
31st Mar 2020 8:45pm |
Cool will look into that also then when this new bonnet comes 1999 Land Rover Defender 110 td5 station wagon
31st Mar 2020 9:24pm |
Oldowner Member Since: 26 Dec 2018 Location: South west Posts: 625 |
Also known as a complete bodge. |
1st Apr 2020 6:23am |
This is how not to bodge it. Rear tub chequerplate removal.
1st Apr 2020 6:26am |
VVS210 Member Since: 12 Nov 2016 Location: Hampshire Posts: 953 |
Or a perfectly functional bush fix for someone who has neither the kit to TIG weld themselves or the opportunity/funds to take it to someone to weld it for them |
1st Apr 2020 6:35am |
Thanks for that. Not everybody has access to a tig welder Darren
1st Apr 2020 7:03am |
