Home > Technical > TD5 Injector codes
LandymanStefan
England 2001 Defender 90 Td5 SW Epsom Green
TD5 Injector codes
Been having lots of issues with my td5 but a very long story short i bought a new ECU, i read the injector codes on the nanocom from the old ecu and put them into the newer one. Car runs fine...
Howver with all this time off i decided to change my rocker cover gasket and interestingly all the codes on the back of the injectors were different to what i got from the original ecu.
Should i update the ECU with codes on the top of the injectors? I took a pictre of them all before i put the lid back on.
Post #821443 26th Mar 2020 12:02pm
Martin
Site Admin
Yes you should put the actual codes into the ECU Smile  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #821445 26th Mar 2020 12:14pm
LandymanStefan
Which end is injector no 1 at? Bulkhead end or inector harness plug end?
Post #821448 26th Mar 2020 12:36pm
dorsetsmith
cylinder one timing chain end
Post #821449 26th Mar 2020 12:38pm
LandymanStefan
Thanks! Thumbs Up
Edit: All done and running fine
Post #821451 26th Mar 2020 12:46pm
T140
Scotland 2007 Defender 90 Td5 HT Zambezi Silver
a quick tip, write the codes on the rocker cover with a sharpie this saves removing the rocker cover to read the codes the next time you need them. nobody is perfect but being Scottish is a start
Post #821476 26th Mar 2020 4:40pm
