Home > Technical > TD5 Injector codes |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6605 |
Yes you should put the actual codes into the ECU 1988 90 Td5 NAS soft top
2015 D90 XS SW |
26th Mar 2020 12:14pm |
LandymanStefan Member Since: 30 Aug 2017 Location: Surrey Posts: 881 |
Which end is injector no 1 at? Bulkhead end or inector harness plug end?
26th Mar 2020 12:36pm |
cylinder one timing chain end
26th Mar 2020 12:38pm |
Thanks!
Edit: All done and running fine |
26th Mar 2020 12:46pm |
T140 Member Since: 15 Mar 2016 Location: Ayrshire Posts: 173 |
a quick tip, write the codes on the rocker cover with a sharpie this saves removing the rocker cover to read the codes the next time you need them. nobody is perfect but being Scottish is a start
26th Mar 2020 4:40pm |
