Home > My Defender > a 130 itch
Page 19 of 21 <123 ... 18 192021>
jst
Well, m57 background work started a while ago when I upgraded front calipers. Pad contact area seems same as std front pads although discs are bigger dia, bigger vented gap. Unloaded there is minimal difference, towing or loaded they are far better than std brakes. Yes I know lots will say std brakes are fine and for 90% of the time they are. But extra weight of the 130 when she is all up with camping gear and towing makes it a heavy lump and the greater dia discs certainly help, they seem to cool better too which going auto will be useful living in a hilly area towing regularly.
These have been on 12mths now.
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1019531 29th Dec 2023 12:34pm
jst
So mud outweighed rust, one mudflap off. Gwyn Lewis to the rescue. Mounted them high to cover the end of the side sills. hopefully they are still long enough. Should stop crud going up the side.
James
110 2012 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1019558 29th Dec 2023 5:26pm
jst
Making a start.
James
110 2012 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1025193 19th Feb 2024 4:15pm
TexasRover
Did the same Gwyn Lewis from flap shield and brackets. Beautiful natural fit. Looks factory and provides a whole bunch of protection! Nice piece of kit.
Post #1025195 19th Feb 2024 4:32pm
JOW240725
Bye bye Puma Thumbs Up James
Instagram @suffolk_rovers
Post #1025196 19th Feb 2024 4:40pm
jst
Well that was fun. What a time consuming job removing a 2.4 compared to most other lr engines.
James
110 2012 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1025694 23rd Feb 2024 11:23am
It's a big lump when it's in one piece!
Post #1025714 23rd Feb 2024 1:19pm
jst
Sure is. Easier though if crane or lift is upto the job I think Cheers
James
110 2012 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1025779 24th Feb 2024 12:20am
jst
It's always nicer putting things together.
James
110 2012 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1025793 24th Feb 2024 8:11am
Jon w
Wales 1991 Defender 90 200 Tdi HT Epsom Green
You did well getting it out all in 1 lump. with the angles etc and getting it over the front crossmember. When I did the 200tdi it was hard enough to keep the transfer box up off the floor and sump up and over the front crossmember.
Post #1026138 27th Feb 2024 1:03pm
jst
have done the last few like that, a long reach engine crane and ratchet strap to bring t box up one its been brought fwd a little. is quite heavy though Cheers
James
110 2012 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1026152 27th Feb 2024 2:46pm
Les Brock
Cracking on I see. Bow down
Wish I had the space, things take so much longer when your fighting for room
Be GB and TB in 1st then bolt it together in situ Very Happy
Post #1026200 27th Feb 2024 7:43pm
jst
half the 130 was out the garage to lift the lumps in! saw your thread on garage not been long enough for you 90, think how a 130 goes!
cooling pack in in now and gbox cooler sorted.
waiting on last ac pipe and fuel fittngs then some wiring to do. hoping engine turn end of this week, Cheers
James
110 2012 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1026266 28th Feb 2024 3:27pm
jst
Getting there....
James
110 2012 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1027277 8th Mar 2024 12:58pm
jst
Well it's been a bit love hate at times but agro will be worth it.
James
110 2012 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1033875 5th May 2024 3:31pm
