Home > Puma (Tdci) > Problems I’ve had in 10 yrs
Page 2 of 2 <12
parktag
France 2008 Defender 130 Puma 2.4 HCPU Zermatt Silver
After 12 years and 110.000km
Steering box after 2 years
New uprated clutch and slave cylinder
Bought a new water pump but only needed a gasket
New front brake callipers, old ones fitted with new pistons so are good to use again
Swivel seals leaking but rebuilt hubs at the same time because of vague steering.
New EGR valve
Reverse light switch
Indicator relay x3
Not too bad really. I don't do many long journeys but it does get used every day including dragging large oak and pine trees around my forest. 130 crew cab
98 V8 Disco
Post #820326 20th Mar 2020 9:53am
X4SKP
So in the Spirit of this thread mines 10 years old (end of this year)
I've owned it for 7 years and done 36 of its 42K mileage.
Problems
X1 Breather Pipe
X1 Wheel Bearing
X1 Ignition Barrel
X1 Indicator Bulb
X1 Gearbox Rubber Mount
Periodic MAF Fault Code warning (proper cleaning fluid looks to have sorted)
Main Jobs done (some OCD / some learning curve)
Fixed Problems listed above
All Wheel Bearings repacked
X1 New Starter Motor (ref mis-diagnosed Ignition Barrel)
X1 New Battery (ref mis-diagnosed Ignition Barrel)
X1 Dinitrol Treatment (follow up refresh treatment this year)
X12 Services (2 of which were all oils change)
X? Security Layers installed
X1 Happy Owner... Thumbs Up SKIP
Post #820374 20th Mar 2020 4:47pm
Siwynne
2013 110 usw Purchased at 30k miles in May 2015
Problems
Warranty
1xclutch & shaft.
Fuel breathers
Intercooler hoses x3
Cylinder head (replaced under warranty in error It took three months it was a split intercooler)
Fuel pump (broken when head was off)
Leaking timing chain cover (head again)
Intercooler replaced
All servicing done by me even in warranty
All fluids replaced by myself at purchase
Now outside warranty
Dinitroled
All servicing done by me oils when required.
New drive members
New discs and pads all round
New nsf stub axel (Damaged thread)
Fixed wiper relay by hitting it on gear stick
Painted corroded mirror arms , bumper , crossmember side steps mudflap brackets
Post #820432 20th Mar 2020 9:59pm
LR90XS2011
mines 9 yrs old but low mileage owned from new, quite a few bits upgraded but the only parts replaced due to imminent failure under warranty at 4 years old are the clutch (rattling) and transfer shaft (excessive play) both known puma weak points. The only part replaced due to failure was the battery but this was because of my intermittent use and being too lazy to put it on a trickle charger. DEFENDER 90 TDCI XS,
Post #820457 21st Mar 2020 7:27am
Zed
United Kingdom 2010 Defender 110 Puma 2.4 XS CSW Santorini Black
There isn’t enough space on the internet to list all my parts failures. WARNING.
This post may contain sarcasm.
Post #820459 21st Mar 2020 8:03am
LR90XS2011
LOL DEFENDER 90 TDCI XS,
Post #820465 21st Mar 2020 8:30am
topless_matt
Oh dear, my list may be a littler longer but the defender gets worked HARD!!
New engine at 77k now on 105
New wheel bearings all round twice
2 ujs
New brake pads twice and discs once
New drive flanges twice
One rear half shaft
One calliper
One turbo prior to engine change
Expansion tank replaced
Transfer box intermediate shaft
Ashcroft output shaft fitted while transfer box out
Diff lock switch
All in 5 years of ownership Hold my beer and watch this!
Post #820469 21st Mar 2020 8:44am
Page 2 of 2 <12
