![]() | Home > Puma (Tdci) > 2007 90: Knocking in driver floor panel on turns |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8204 ![]() ![]() ![]() |
I presume you checked by nothing moving in battery box Cheers
ter11 Member Since: 28 Oct 2015 Location: Zurich Posts: 26 ![]() ![]() ![]() |
Thanks. And yes, battery is strongly fixed in place as should be.
topless_matt Member Since: 29 Mar 2015 Location: norfolk Posts: 68 ![]() ![]() ![]() |
Locking wheel nut key? Wheel wrench? Jack moving about. Doesn’t take much of a knock to sound bad through the panels. Hold my beer and watch this!
Something behind passenger seat
Stone in chassis rails Trailing arm, radius bush? Panhard? Gbox mounts Exhaust rubbers, movement? Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
Vogler Member Since: 02 Nov 2014 Location: Brussels Posts: 309 ![]() ![]() ![]() |
Noises can be very deceiving, I once was convinced to hear knocking from the rear right, but it turned out to be the front left when listened to from the outside.
A good way to locate worn bushes or suspension parts is by chocking a rear wheel with blocks in front and behind the wheel, leaving some 2-3cm/1in of play. Then rock the car back and forth. I used wooden blocks approx 5cm/2in thick,and it helped me to locate a worn bush in seconds. Good luck, J Antares Treadwell, a MY06 110 Td5 in Chawton White |
sharkey964 Member Since: 05 Oct 2014 Location: On a muddy track Posts: 583 ![]() ![]() ![]() |
Check the steering stops,if one has vibrated loose,then the tyre could be catching on the radius arm.
Marc. |
find the answer ? Cheers
michail1976 Member Since: 09 Jun 2018 Location: Krasnoyarsk Posts: 3 ![]() ![]() ![]() |
Check the condition of the hood hinges
jeffersj Member Since: 23 Jan 2015 Location: Near Preston Posts: 431 ![]() ![]() ![]() |
As sharkey says the lock stop bolt could have loosened or maybe you have fitted wider tyres which catching the chassis. Jeff
Or tyre pressure dropped on lhf. Cheers
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20715 ![]() ![]() |
Front damper bushes are possible too. WeWillWin🇬🇧🇺🇸
