Home > Puma (Tdci) > 2007 90: Knocking in driver floor panel on turns
ter11
Switzerland 2007 Defender 90 Puma 2.4 SVX Station Wagon Santorini Black
Hi all
Recently my 2007 90 td4 (45k mls) has developed a knocking noise and feeling in the driver side (LHD) foot panel, when I do left or right turns or drive over bumps/potholes.
I feels like if a heavy tool was in the battery box or under the foot panel sliding into the body wall upon turns.
Under the car I cannot find any loose screws (foot panel, prop shaft, steering etc).
The front springs are perfectly stable and do not touch the body.
Any hints anybody?
Br
Ter
Post #817408 28th Feb 2020 4:12pm
jst
I presume you checked by nothing moving in battery box Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #817461 28th Feb 2020 9:48pm
ter11
Thanks. And yes, battery is strongly fixed in place as should be.
Post #817490 29th Feb 2020 6:51am
topless_matt
England 2007 Defender 90 Puma 2.4 HT Tonga Green
Locking wheel nut key? Wheel wrench? Jack moving about. Doesn’t take much of a knock to sound bad through the panels. Hold my beer and watch this!
Post #817493 29th Feb 2020 7:17am
jst
Something behind passenger seat
Stone in chassis rails
Trailing arm, radius bush? Panhard?
Gbox mounts
Exhaust rubbers, movement? Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #817496 29th Feb 2020 7:42am
Vogler
Belgium 2015 Defender 110 Td5 HT Chawton White
Noises can be very deceiving, I once was convinced to hear knocking from the rear right, but it turned out to be the front left when listened to from the outside.
A good way to locate worn bushes or suspension parts is by chocking a rear wheel with blocks in front and behind the wheel, leaving some 2-3cm/1in of play. Then rock the car back and forth.
I used wooden blocks approx 5cm/2in thick,and it helped me to locate a worn bush in seconds.
Good luck,
J Antares Treadwell, a MY06 110 Td5 in Chawton White
Post #817542 29th Feb 2020 3:02pm
sharkey964
France 2007 Defender 90 Puma 2.4 XS CSW Santorini Black
Check the steering stops,if one has vibrated loose,then the tyre could be catching on the radius arm.
Marc.
Post #817556 29th Feb 2020 4:35pm
jst
find the answer ? Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #818193 4th Mar 2020 8:33pm
michail1976
Russia 2014 Defender 110 Puma 2.2 CSW Oslo Blue
Re: 2007 90: Knocking in driver floor panel on turns
Check the condition of the hood hinges
Post #818231 5th Mar 2020 4:17am
jeffersj
United Kingdom 1996 Defender 90 300 Tdi HT Bronze Green
As sharkey says the lock stop bolt could have loosened or maybe you have fitted wider tyres which catching the chassis. Jeff
Ex 1968 Series 2A
Ex 90 TD5
Ex D3
Ex D4
Post #818253 5th Mar 2020 9:18am
jst
Or tyre pressure dropped on lhf. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #818571 6th Mar 2020 10:59pm
Front damper bushes are possible too. TheThunder Rolls🇬🇧🇺🇸
Post #818575 6th Mar 2020 11:15pm
