Home > Puma (Tdci) > 2007 90: Knocking in driver floor panel on turns |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8027 |
I presume you checked by nothing moving in battery box Cheers
James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
28th Feb 2020 9:48pm |
ter11 Member Since: 28 Oct 2015 Location: Zurich Posts: 26 |
Thanks. And yes, battery is strongly fixed in place as should be.
29th Feb 2020 6:51am |
topless_matt Member Since: 29 Mar 2015 Location: norfolk Posts: 68 |
Locking wheel nut key? Wheel wrench? Jack moving about. Doesnโt take much of a knock to sound bad through the panels. Hold my beer and watch this!
29th Feb 2020 7:17am |
Something behind passenger seat
Stone in chassis rails Trailing arm, radius bush? Panhard? Gbox mounts Exhaust rubbers, movement? Cheers James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
29th Feb 2020 7:42am |
Vogler Member Since: 02 Nov 2014 Location: Brussels Posts: 309 |
Noises can be very deceiving, I once was convinced to hear knocking from the rear right, but it turned out to be the front left when listened to from the outside.
A good way to locate worn bushes or suspension parts is by chocking a rear wheel with blocks in front and behind the wheel, leaving some 2-3cm/1in of play. Then rock the car back and forth. I used wooden blocks approx 5cm/2in thick,and it helped me to locate a worn bush in seconds. Good luck, J Antares Treadwell, a MY06 110 Td5 in Chawton White |
29th Feb 2020 3:02pm |
sharkey964 Member Since: 05 Oct 2014 Location: On a muddy track Posts: 574 |
Check the steering stops,if one has vibrated loose,then the tyre could be catching on the radius arm.
Marc. |
29th Feb 2020 4:35pm |
find the answer ? Cheers
4th Mar 2020 8:33pm |
michail1976 Member Since: 09 Jun 2018 Location: Krasnoyarsk Posts: 3 |
Check the condition of the hood hinges
5th Mar 2020 4:17am |
jeffersj Member Since: 23 Jan 2015 Location: Near Preston Posts: 431 |
As sharkey says the lock stop bolt could have loosened or maybe you have fitted wider tyres which catching the chassis. Jeff
Ex 1968 Series 2A Ex 90 TD5 Ex D3 Ex D4 |
5th Mar 2020 9:18am |
Or tyre pressure dropped on lhf. Cheers
6th Mar 2020 10:59pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20364 |
Front damper bushes are possible too. $W33T $0U7H3RN $UG4R
๐ฌ๐ง๐ด๓ ง๓ ข๓ ฅ๓ ฎ๓ ง๓ ฟ๐ด๓ ง๓ ข๓ ท๓ ฌ๓ ณ๓ ฟ๐ด๓ ง๓ ข๓ ณ๓ ฃ๓ ด๓ ฟ๐ฎ๐ช๐บ๐ธโฝ๏ธ๐ข๏ธโ๏ธ๐งฐ๐ช |
6th Mar 2020 11:15pm |
