![]() | Home > Technical > Washer pump size or grommet |
Tegner Member Since: 31 Jul 2018 Location: Alnwick Northumberland Posts: 189 ![]() ![]() ![]() |
Hi Keith if its the same as a TDCI the part No. is RTC 3959 pity your not closer I have a spare
regards Ken |
drakes Member Since: 09 Oct 2009 Location: Hexham Posts: 113 ![]() ![]() ![]() |
Tegner
Is it possible you could measure the ID of the grommet as I think it is the same one. Keith |
Hi swapped my pump for the Optimill set up internal diameter 8mm where the pump sits
diameter for the washer tank 12mm |
Thanks that's what I needed to know
Keith |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17622 ![]() ![]() ![]() |
TDCi and TD5 are the same.
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6145 ![]() ![]() ![]() |
And a freelander washer pump fits straight in! slightly taller than the Td5 one, but (in my case) pumps a helluva lot better than the cr@ppy pump I had in place before.
I use a Disco 2 headlamp washer pump for my screenwasher, and a Rover 25 headlamp washer pump, which is essentially the same, for the headlamp washers.
Both are much more powerful and shift much more fluid than the standard screen washer pump. |
Roy5695 Member Since: 15 Feb 2014 Location: Cornwall Posts: 1123 ![]() ![]() ![]() |
I also use a discovery headlight washer pump. Coupled with a bigger internal diameter pipe (10mm) and a CSI washer jet nozzle. It’s incredible.
Although I did have to power the new washer pump with a relay as it draws about 17Amps 😬 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html Instagram - @r22oyp Roy |
Both my pumps have their own relay.
