Home > Technical > Washer pump size or grommet
drakes
United Kingdom 2004 Defender 90 Td5 HT Auto Belize Green
Has anyone got a screen wash pump at hand ( one that fits a TD5 not sure what else it may fit ) that they could measure for me. What I need to know is the OD of the bit that fits into the grommet in the washer reservoir or the ID of the grommet if you have one of those.
Thanks
Keith
Post #815773 18th Feb 2020 11:45am
Tegner
United Kingdom 2010 Defender 90 Puma 2.4 HT Zermatt Silver
grommet
Hi Keith if its the same as a TDCI the part No. is RTC 3959 pity your not closer I have a spare
regards
Ken
Post #815815 18th Feb 2020 4:15pm
drakes
Tegner
Is it possible you could measure the ID of the grommet as I think it is the same one.
Keith
Post #815817 18th Feb 2020 4:21pm
Tegner
Grommet
Hi swapped my pump for the Optimill set up internal diameter 8mm where the pump sits
diameter for the washer tank 12mm
Post #815819 18th Feb 2020 4:27pm
drakes
Thanks that's what I needed to know
Keith
Post #815820 18th Feb 2020 4:31pm
TDCi and TD5 are the same.
Post #815846 18th Feb 2020 6:32pm
And a freelander washer pump fits straight in! slightly taller than the Td5 one, but (in my case) pumps a helluva lot better than the cr@ppy pump I had in place before.
Post #815929 19th Feb 2020 6:52am
I use a Disco 2 headlamp washer pump for my screenwasher, and a Rover 25 headlamp washer pump, which is essentially the same, for the headlamp washers.
Both are much more powerful and shift much more fluid than the standard screen washer pump.
Post #815989 19th Feb 2020 1:21pm
Roy5695
I also use a discovery headlight washer pump. Coupled with a bigger internal diameter pipe (10mm) and a CSI washer jet nozzle. It’s incredible.
Although I did have to power the new washer pump with a relay as it draws about 17Amps 😬 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html
Instagram - @r22oyp
Roy
Post #816210 20th Feb 2020 9:01pm
Both my pumps have their own relay.
Post #816226 20th Feb 2020 10:20pm
