Home > Td5 > TD5 wont start |
davidblythe Member Since: 27 Apr 2019 Location: Cheam, Surrey Posts: 110 |
Hi these 3 fuses in particular where are they cant see them under the seat or under the dash
9th Feb 2020 6:19pm |
Fuse td5 02 to 06
https://www.lrworkshop.com/electrics/defen...nd-headers |
9th Feb 2020 6:26pm |
thank you
9th Feb 2020 6:40pm |
Merlin Member Since: 30 Oct 2010 Location: Newmarket Posts: 981 |
On mine, might be different on yours, F21 is the hazard fuse but also the AS10. Can be overlooked. Peter
9th Feb 2020 6:47pm |
as a final follow up
had the ecu tested by ecu testing, then repaired £324 and the truck is as good as new with a life time warranty on the ECU |
3rd Apr 2020 9:48am |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5842 |
Did they say what was up with the ECU? 1999 Defender TD5 110
3rd Apr 2020 10:17am |
No They didnt, did ask but got no reply
guess they like to keep the knowledge hidden and I would too |
3rd Apr 2020 10:20am |
does a disco nnn works okay on a defender as is subject to injector values ?
3rd Apr 2020 3:47pm |
LandymanStefan Member Since: 30 Aug 2017 Location: Surrey Posts: 881 |
Works fine, just typed in the injector codes in the nanocom and put a defender fuel map in it and it seems fine
3rd Apr 2020 3:48pm |
