Home > Td5 > TD5 wont start
davidblythe
TD5 wont start
Lost and need help
TD5 90 with immobiliser has run and started fine all year, tonight using either key can set immobiliser and disarm immobiliser
have a strong battery, engine turns over strongly but will not fire
At a loss any pointers please
Post #812949 31st Jan 2020 8:37pm
Does the temperature guage go to "max" when you turn the ign on?
If so, the rollover switch under the bonnet needs resetting
Post #812951 31st Jan 2020 8:40pm
davidblythe
No it moves to cold only
where is this switch for future reference
Post #812953 31st Jan 2020 8:43pm
https://www.defender2.net/forum/post421658.html for the switch.
Could be anything really.... can you hear the fuel pump whirr when youo turn the ign on?
worth wiggling the CPS (Crank position sensor), on the bellhousing, kind of underneath where the above switch is
But without some form of diagnostic machine, you could be grasping at straws.
Relays in the battery box are often a cause of issues... worth giving them a wiggle
Post #812954 31st Jan 2020 8:46pm
landy andy
I’m sure you have tried the close all the doors, lock with remote, leave a few mins then unlock try start?
Next thought is can you hear fuel pump?
If yes check clean crank sensor, refit and try.
You could then try a tow start, sometimes it can be a dodgy starter putting an electrical spike doofa thing up the thingy.
Post #812968 31st Jan 2020 9:24pm
davidblythe
yes to closing doors etc
can hear fuel pump
battery voltage is 12.8v
can see no oil in ecu
friends solus edge diagnostic equipment showed no codes
next to try crank sensor
Post #813045 1st Feb 2020 11:05am
roel
Netherlands 2003 Defender 90 Td5 PU Caledonian Blue
What is the voltage while turning over? If it drops below 9V orso the ECU shuts down so no diesel will be injected.
Sounds to me or as mentioned one off the relays under the seat or your AS10 doesn't want to do it's thing.
What you could try is disconecting the black plug from your ECU (under the seat) and plug it back. Do the same with the relays maybe a bad connection might confuse the ecu. Roel
1984 90 2.5 na Diesel - RR V8 (1994-2001)
1997 Camel Trophy Discovery 300TDI (2001-2009)
2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts.
2003 90 Td5 (2009-now)
Post #813100 1st Feb 2020 5:13pm
renoclio255s
United Kingdom 2000 Defender 110 Td5 HT Alpine White
hi, have you got fuel in the system if so check the pressure it should be around 60psi. If not could be pressure regulator on rear right hand of head. If not try fuel filter housing there are some valves in there that removes the air from the system
Post #813726 5th Feb 2020 9:49am
davidblythe
tried a new fuel filter on the 90 and primed it with diesel, it is going through its cycle to purge air but keeps on repeating as it was doing before the filter change
having also changed the fuel filter on my 110 and it purging with 3 turns of the key and starting straight after
why is the 90 not purging the air any pointers
Post #813775 5th Feb 2020 6:04pm
lightning
Faulty non return valve in the diesel filter housing?
Post #813781 5th Feb 2020 6:32pm
Merlin
Have you checked it's not the accident cut-out switch on the bulkhead?
Post #813916 6th Feb 2020 3:27pm
excossack
Have you tried with a bump start? 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #813918 6th Feb 2020 3:31pm
Silvertoolbox
Immobiliser battery? Or battery retainer in handset. Can break and give intermittant operation.
Think number of flashes (indicators) gives a clue re battery health. Ex scottish & southern 110 Td5 van (shed) with PTO driven winch (L-R special vehicles)
Before that, Disco 1, Freelander 1, 26105382 80" with a 1600cc (not much slower)
Post #813963 6th Feb 2020 7:47pm
davidblythe
today i disconnected the high pressure feed to the cylinder head. once the key was turned to the start position, diesel spurted continously out of the pipe, can i assume the fuel tank pump is working
i also removed the rocker cover to make sure the cam chain was rotating once the engine was cranked
still no attempt to start, i need to check the crank position sensor, cant locate it at the minute
any feedback appreciated
Post #814360 9th Feb 2020 5:40pm
Merlin
Are you suspecting the alarm module? If it's the AS10 like mine I would check the 3 fuses just to be sure. Peter
Post #814363 9th Feb 2020 5:49pm
