Home > Maintenance & Modifications > Transfer Box and Diff Oil |
X4SKP Member Since: 29 Nov 2013 Location: Berkshire Posts: 2295 |
Good Luck SKIP
https://www.defender2.net/forum/topic83242.html |
1st Feb 2020 6:17pm |
roel Member Since: 08 Aug 2009 Location: Lelystad Posts: 2039 |
Gearbox has different oil. MTF I believe.. Roel
1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
19th Nov 2022 6:22pm |
BrickBox Member Since: 05 Oct 2021 Location: Wales Posts: 809 |
Reading back a page, I thought the gear 300 was for all the driveline? 2008 2.4 110 Utility Station Wagon XS.
19th Nov 2022 6:24pm |
MatLandy Member Since: 11 Sep 2020 Location: Paris Posts: 184 |
MT82 Gearbox requires oil that meets Ford WSD-M2C200-C specifications. At least this is what is stated in the workshop manual.
I use Castrol Transmax Manual Multivehicle 75W-90 (which replaces Castrol Syntrans Multivehicle 75W90), just because it says it meets this spec on the box. It gives me peace of mind… /Mat |
20th Nov 2022 8:28am |
MTF was used in earlier boxes but not in the MT82 in Puma engined vehicles. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
20th Nov 2022 8:40am |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2414 |
Ford WSD-M2C200-C is PAO based. You can get away with non PAO based oil meeting 75w90 visc and GL-4 rating. Just need to change it more often. Puma 110" SW
20th Nov 2022 12:21pm |
https://www.amazon.co.uk/Castrol-55761-Tra...&psc=1 2008 2.4 110 Utility Station Wagon XS.
6th Feb 2023 1:11pm |
nitram17 Member Since: 08 Jun 2014 Location: newcastle Posts: 2261 |
just ordered this of Amazon......hope its not a knock off!
https://www.amazon.co.uk/Motul-105777-1001...mp;sr=8-10 |
21st Feb 2023 2:55am |
stephan123 Member Since: 18 Mar 2015 Location: London Posts: 282 |
I plan on replacing the gearbox/axle oils as part of my upcoming Service B but not sure if the drain plugs must also be replaced as done when changing the engine oil....any advice would be much appreciated!
10th Feb 2024 11:19am |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5692 |
You do not need to put purchase new drain or filler plugs. Unless you plan an upgrade in plug type.
10th Feb 2024 12:04pm |
Many thanks! Also, from what I've read, it seems that the filler plug level should be used for the transfer box and axles whereas the gearbox needs a specific amount of oil. Is this correct?
10th Feb 2024 4:58pm |
Yes that is correct unless you have a proper Defender
All the information is here. https://www.defender2.net/forum/topic8707.html |
10th Feb 2024 5:08pm |
