Home > Technical > Check engine light reset.
Callum_P
Hi everyone, I recently came home after working away over Christmas and new year and started up the Landy.
I let it tick over for a little while, whilst I got ready to go out.
When I jumped in the landy the check engine and DPF “red” light was on.
Shortly after I drove away the red DPF became amber then cleared all together, however the check engine light has stayed on.
Will I need a code reader to clear this?
Any help appreciated and apologies if this has been discussed 100 times before.
Kind regards
Callum
(2.2tdci 2012 110 USW)
Post #810403 15th Jan 2020 5:40pm
kmac
You will need a code reader that can reset the light - cheaper ones can read codes but not reset.
But before resetting check what the code is so you can remediate if needed.
Depending where you are you may be able to borrow from another forum member near you.....I see that you are in Shetland - wow - however I am sure there will be other Defender owners there.
To just read and clear codes you don't need a Defender specific tool, a generic one will also do the job.
Post #810503 16th Jan 2020 9:05am
Callum_P
Thanks Kmac, I thought I might need it plugged in.
Yup I’m from Shetland born and bred, also a committee member of the local Land Rover club.
We have around 50 members. “Britain’s top club”
www.shetlandlrc.org.uk or find us on FB for club news and events or if you’re travelling here and stuck.
Post #810519 16th Jan 2020 10:34am
kmac
Thumbs Up
Post #810683 17th Jan 2020 10:49am
