![]() | Home > Technical > Check engine light reset. |
kmac Member Since: 07 Oct 2009 Location: Middlesex Posts: 1315 ![]() ![]() ![]() |
You will need a code reader that can reset the light - cheaper ones can read codes but not reset.
But before resetting check what the code is so you can remediate if needed. Depending where you are you may be able to borrow from another forum member near you.....I see that you are in Shetland - wow - however I am sure there will be other Defender owners there. To just read and clear codes you don't need a Defender specific tool, a generic one will also do the job. |
Callum_P Member Since: 08 Aug 2016 Location: Shetland Posts: 11 ![]() ![]() |
Thanks Kmac, I thought I might need it plugged in.
Yup I’m from Shetland born and bred, also a committee member of the local Land Rover club. We have around 50 members. “Britain’s top club” www.shetlandlrc.org.uk or find us on FB for club news and events or if you’re travelling here and stuck. |
