![]() | Home > Technical > Unlock flash has gone! |
ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1833 ![]() ![]() ![]() |
I would guess one of the locks is 'bouncing' try wd40 everything to see if it frees up - can even be the interior vertical lock pegs jamming.
HTH Keith |
Timcat Member Since: 20 Jul 2016 Location: Rugby at the moment Posts: 1025 ![]() ![]() ![]() |
Thanks for the reply, just gone out to move it off the drive & it had locked its self running! Had to use the spare key to unlock it ( once I'd de-frosted the lock) Will have to see if I can see which ones sticking, failing that it will be door cards off.
ARC99 Member Since: 19 Feb 2013 Location: North Yorkshire Posts: 1831 ![]() ![]() ![]() |
Just a thought, are all your doors closed fully, mine was doing the same and |I found that the back door wasn't lactching over fully. Don't make old people mad.
We don't like being old in the first place, so it doesn't take much to ![]() Richard |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4796 ![]() ![]() ![]() |
Not flashing on unlock is the alarms way of telling you that the key fob battery is low
![]() 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
