Home > Technical > Unlock flash has gone!
Timcat
United Kingdom 2012 Defender 110 Puma 2.2 SW Indus Silver
As per title, 2012 station wagon. When you press the fob the hazards used to flash once for opening & twice for locking. Still double flash on the locking but nothing on the opening! Plus this morning the central locking has gone haywire locks & unlocks repeatedly ( read it might be the cold -2 here) Thoughts?
Post #804396 2nd Dec 2019 7:14am
ickle
I would guess one of the locks is 'bouncing' try wd40 everything to see if it frees up - can even be the interior vertical lock pegs jamming.
HTH Keith
Post #804397 2nd Dec 2019 7:20am
Timcat
Thanks for the reply, just gone out to move it off the drive & it had locked its self running! Had to use the spare key to unlock it ( once I'd de-frosted the lock) Will have to see if I can see which ones sticking, failing that it will be door cards off.
Post #804401 2nd Dec 2019 7:47am
ARC99
United Kingdom 2008 Defender 110 Puma 2.4 USW Cairns Blue
Just a thought, are all your doors closed fully, mine was doing the same and |I found that the back door wasn't lactching over fully. Don't make old people mad.
We don't like being old in the first place,
so it doesn't take much to Censored us off.
Richard
Post #804403 2nd Dec 2019 8:00am
grafty99
Not flashing on unlock is the alarms way of telling you that the key fob battery is low Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #804408 2nd Dec 2019 9:10am
