Home > Technical > Clunk diagnosis
Page 2 of 2 <12
PCM
Clunk diagnosis. Output shaft.
Love the wavy pattern on the teeth.
Post #888242 28th Feb 2021 8:39am
JPE
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Firenze Red
When I first got my defender a couple of years ago I spent quite a lot of time reading all about the causes of my clunk.
I changed to 1 piece half-shafts which helped a bit, but other than that there just seemed to be little bits of slack here and there but nothing that seemed badly wrong.
Over the last 2 years its got much better, only rarely clunking & I don't think about it much any more.
I think that's just down to my driving style adapting! Smile
Post #888342 28th Feb 2021 8:15pm
Rear damper bushes are worth looking at too, they can do this due to front to rear weight transfer.
The rear uppers when going tend to knock and the rear lowers go on quite low miles.
Guess who has to change these very soon.
Often only on one side it can be worse than the other.
Move the Defender body around and look and listen for it. The fronts Iโ€™ve never had issues with.
Worth checking, itโ€™s not always driveline related. Even the bonnet hinges can make you think itโ€™s something else all together. KEEP CALM AND Drill ON
๐Ÿ‡ฌ๐Ÿ‡ง๐Ÿด๓ ง๓ ข๓ ฅ๓ ฎ๓ ง๓ ฟ๐Ÿด๓ ง๓ ข๓ ท๓ ฌ๓ ณ๓ ฟ๐Ÿด๓ ง๓ ข๓ ณ๓ ฃ๓ ด๓ ฟ๐Ÿ‡ฎ๐Ÿ‡ช๐Ÿ‡บ๐Ÿ‡ธโ›ฝ๏ธ๐Ÿ›ข๏ธโš™๏ธ๐Ÿงฐ๐Ÿ’ช
Post #888362 28th Feb 2021 9:49pm
FD7
2006 Defender 90 V8 Petrol ST Auto Chawton White
I chased my tail a bit on this and before almost giving up the final bushes replacement solved it.
Admittedly its all quite cheap to resolve! It all made improvements along the way... they did warn me owning an old car would have its pitfalls at times..
Post #889113 4th Mar 2021 9:20pm
Page 2 of 2 <12
