Home > Maintenance & Modifications > Oil Catch Can - Provent Alternative II ~ Ryco
Page 2 of 3 <123>
hank
I saw this in another thread. Made sense to me
blackwolf wrote:
Personally I would not for one second consider returning the gunk that drains out of the Provent into the sump. I know that it can be done, but once you've seen what comes out of the Provent (a mix of condensed oil vapour, condensed water vapour, and blow-by byproducts), you won't want to either.
 > 110 XS Double Cab
Post #804989 6th Dec 2019 2:02pm
rallysteve
As i said it is just out of the crank case (as it is an alternative crank breather system)
The point of the Provent is separate oil droplets from the crankcase fumes before returning the fumes to the inlet. This is exactly what the standard system is meant to achieve but doesn't do it well at all. Hence the standard system feeds a lot of oil vapour into the inlet tract/turbo/intercooler.
Since fitting my Provent the intercooler and hoses are spotlessly clean.
I currently just have a section of capped pipe on my Provent drain which i empty periodically. It is just normal used engine oil. If there is anything other than oil in it then it has originated from inside the engine. There certainly shouldn't be any measurable amount of water in it!
I might run my own drain back into the sump next time i have the sump off so i can drill and tap a suitable fitting in although i quite like being able to monitor the amount of oil collected vs. mileage The one way valve mentioned is to stop engine oil being sucked back from the sump through the Provent due to the negative pressure in the inlet during engine running.
Running crankcase fumes back into the engine once the oil droplets are removed isnt an issue. After all, combustion gasses did come from the cylinders! Venting to atmosphere just makes a closed system open and is not what the Provent is intended for and is a needless engine emission to the environment.
Post #804991 6th Dec 2019 2:28pm
tolley
United Kingdom 2006 Defender 90 Td5 CSW Oslo Blue
ive ordered the 150 for my 300tdi just got to work out the best route to fit Confused
Post #805020 6th Dec 2019 5:35pm
This looks amazing to me - and maybe more proof that having this closed loop without engineering in a trap/filter just creates new issues for the owner down the line.
This issue goes all the way back to 2016 engines.
Alert number: A12/1953/19
Category: Motor vehicles
Product: Passenger car
Brand: Volvo
Name: S60, V60, V40, V40CC, S90, V90, V90CC and XC90
Type / number of model: VIN range: LVYPS68BCJP035125* - YV1PZ68BCJ1036844*
Batch number / Barcode: The affected vehicles are from model year 2016 - 2019;
Risk type: Fire
Due to an excessive build-up of carbon deposits in the intake system, the plastic engine intake manifold may melt and deform. As a result, a localized engine bay fire may occur.
Measures taken by economic operators: Recall of the product from end users (By: Distributor)
Description: Passenger cars equipped with four-cylinder diesel engine D4204T8 (engine code 74), D4204T11 (A4), D4204T6 (A7) and D4204T23 (6Cool under Volvo recall code: R 29945.
Country of origin: Sweden
Alert submitted by: Portugal
Type of alert: Serious
Products were found and measures were taken also in: Germany, Poland
https://ec.europa.eu/consumers/consumers_s...amp;lng=en
Post #806040 13th Dec 2019 9:25am
2010Blackdefender90
United Kingdom 2011 Defender 90 Puma 2.4 SVX Station Wagon Santorini Black
HPD catch can...
Have been searching for a while to find a decent, well made catch can, this arrived today from OZ. It was expensive, but the quality is outstanding. Wire mesh filters, can be cleaned, with a dipstick. Brackets to fit in front of the expansion tank Thumbs Up
Post #810704 17th Jan 2020 1:24pm
Do you have a Web link?
Post #810712 17th Jan 2020 1:54pm
2010Blackdefender90
Post #810713 17th Jan 2020 1:56pm
Zed
United Kingdom 2010 Defender 110 Puma 2.4 XS CSW Santorini Black
Looks good and matches the Nuggetstuff. May have to make a change of plans... WARNING.
This post may contain sarcasm.
Post #810721 17th Jan 2020 3:07pm
2010Blackdefender90
If you look on ebay, their store has shipping to the UK... It’s high, high quality item.
Post #810722 17th Jan 2020 3:11pm
Bluericky
United Kingdom 2009 Defender 110 Puma 2.4 DCPU Keswick Green
Looks like a smart package . The Provent is a little large really and limited in options as to where to put it .
This plug and play system will be far simpler to fit ! https://www.instagram.com/hustynminepark/
Post #810724 17th Jan 2020 3:19pm
2010Blackdefender90
Yep, kit comes complete with brackets, hose, clamps etc
Post #810725 17th Jan 2020 3:22pm
Bluest
Could you post a link, I can't find it on ebay? Did you get stung for import duty? 2007 110 TDCi Station Wagon XS
Post #810728 17th Jan 2020 4:08pm
2010Blackdefender90
https://rover.ebay.com/rover/0/0/0?mpre=ht...2404394931
Nope... covered if you use eBay.... took 4 days to get here Cow
Post #810730 17th Jan 2020 4:16pm
Bluest
Thanks Thumbs Up 2007 110 TDCi Station Wagon XS
Post #810732 17th Jan 2020 4:20pm
xtreme2252
Australia
HPD catch can did not do too good in this comparison
https://www.unsealed4x4.com.au/the-great-o...omparison/
Post #811103 20th Jan 2020 7:37am
Page 2 of 3 <123>
