![]() | Home > Maintenance & Modifications > Oil Catch Can - Provent Alternative II ~ Ryco |
hank Member Since: 12 Sep 2016 Location: South Wales Posts: 2316 ![]() ![]() ![]() |
I saw this in another thread. Made sense to me
> 110 XS Double Cab |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2238 ![]() ![]() ![]() |
As i said it is just out of the crank case (as it is an alternative crank breather system)
The point of the Provent is separate oil droplets from the crankcase fumes before returning the fumes to the inlet. This is exactly what the standard system is meant to achieve but doesn't do it well at all. Hence the standard system feeds a lot of oil vapour into the inlet tract/turbo/intercooler. Since fitting my Provent the intercooler and hoses are spotlessly clean. I currently just have a section of capped pipe on my Provent drain which i empty periodically. It is just normal used engine oil. If there is anything other than oil in it then it has originated from inside the engine. There certainly shouldn't be any measurable amount of water in it! I might run my own drain back into the sump next time i have the sump off so i can drill and tap a suitable fitting in although i quite like being able to monitor the amount of oil collected vs. mileage The one way valve mentioned is to stop engine oil being sucked back from the sump through the Provent due to the negative pressure in the inlet during engine running. Running crankcase fumes back into the engine once the oil droplets are removed isnt an issue. After all, combustion gasses did come from the cylinders! Venting to atmosphere just makes a closed system open and is not what the Provent is intended for and is a needless engine emission to the environment. Steve 02' 110 TD5 Double Cab Rebuild Thread |
tolley Member Since: 07 Nov 2011 Location: gloucester Posts: 1117 ![]() ![]() ![]() |
ive ordered the 150 for my 300tdi just got to work out the best route to fit
This looks amazing to me - and maybe more proof that having this closed loop without engineering in a trap/filter just creates new issues for the owner down the line.
This issue goes all the way back to 2016 engines. Alert number: A12/1953/19 Category: Motor vehicles Product: Passenger car Brand: Volvo Name: S60, V60, V40, V40CC, S90, V90, V90CC and XC90 Type / number of model: VIN range: LVYPS68BCJP035125* - YV1PZ68BCJ1036844* Batch number / Barcode: The affected vehicles are from model year 2016 - 2019; Risk type: Fire Due to an excessive build-up of carbon deposits in the intake system, the plastic engine intake manifold may melt and deform. As a result, a localized engine bay fire may occur. Measures taken by economic operators: Recall of the product from end users (By: Distributor) Description: Passenger cars equipped with four-cylinder diesel engine D4204T8 (engine code 74), D4204T11 (A4), D4204T6 (A7) and D4204T23 (6 ![]() Country of origin: Sweden Alert submitted by: Portugal Type of alert: Serious Products were found and measures were taken also in: Germany, Poland https://ec.europa.eu/consumers/consumers_s...amp;lng=en |
Do you have a Web link?
2010Blackdefender90 Member Since: 07 Jan 2018 Location: London Posts: 562 ![]() ![]() ![]() |
https://hpdiesel.com.au/land-rover-defende...-puma.html
Ordered Monday am, arrived Friday! |
Zed Member Since: 07 Oct 2017 Location: In the woods Posts: 3348 ![]() ![]() ![]() |
Looks good and matches the Nuggetstuff. May have to make a change of plans... WARNING.
This post may contain sarcasm. |
If you look on ebay, their store has shipping to the UK... It’s high, high quality item.
Bluericky Member Since: 26 Jun 2014 Location: Cornwall Posts: 647 ![]() ![]() ![]() |
Looks like a smart package . The Provent is a little large really and limited in options as to where to put it .
This plug and play system will be far simpler to fit ! https://www.instagram.com/hustynminepark/ |
Yep, kit comes complete with brackets, hose, clamps etc
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4230 ![]() ![]() ![]() |
Could you post a link, I can't find it on ebay? Did you get stung for import duty? 2007 110 TDCi Station Wagon XS |
https://rover.ebay.com/rover/0/0/0?mpre=ht...2404394931
Nope... covered if you use eBay.... took 4 days to get here ![]() |
Thanks
xtreme2252 Member Since: 15 Apr 2015 Location: Melbourne Posts: 29 ![]() ![]() |
HPD catch can did not do too good in this comparison
https://www.unsealed4x4.com.au/the-great-o...omparison/ |
