Home > Td5 > 110 Mid-Crossmember Replacement
Page 3 of 3 <123
Titan133
United Kingdom 2004 Defender 110 Td5 CSW Bronze Green
No I think you may be correct. Although I want to get problems fixed properly there’s a limit to my skills. ——————————
2004 110 TD5
Post #963806 2nd Sep 2022 7:22pm
rustandoil
All the parts and panels are available from YRM.... A 5mm drill and a bunch of pop rivits.
Give it a go!
Post #963808 2nd Sep 2022 7:28pm
Titan133
I’ll see what they say. They seem a very good supplier. ——————————
2004 110 TD5
Post #963811 2nd Sep 2022 7:56pm
rustandoil
You will probably end up with something like this
Post #963813 2nd Sep 2022 8:15pm
Titan133
I wouldn’t be averse to doing all that work but my problem is that I need my Defender for work. I can’t keep it off the road for weeks on end. ——————————
2004 110 TD5
Post #963814 2nd Sep 2022 8:31pm
rustandoil
Ah... That would be a problem, it's not a quick job, especially if you find "extra" stuff that needs attention... Brake pipes and fuel pipes and many other things added to my rebuild, I'm trying to do a thorough job.... I don't want to be doing this job again 😊
Post #963815 2nd Sep 2022 8:46pm
lightning
You might get lucky and find that the crossmember is all that's needed.
When l did my 110 mid crossmember there was nothing else needed attention.
l had to cut the corner off those brackets to get the new one in though.
Post #963967 4th Sep 2022 11:32am
Polarismd
blackwolf wrote:
Be careful jacking anything using bricks, it's a definite no-no. They tends to crumble which will cause the load to drop, and this has killed people in the past. Use wood blocks instead.
It was opportune to read this. We just had a guy killed on his driveway propping his Landcruiser on bricks. Found by his stepson, so, please girls and guys "lets be careful out there".
Post #972912 30th Nov 2022 10:25am
Page 3 of 3 <123
