Home > Puma (Tdci) > Limp mode P0101 code help please |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20382 |
Did you ensure it was fitted with the correct airflow direction as marked on the top section?
I’m sure you did, but thought I would mention it. $W33T $0U7H3RN $UG4R 🇬🇧🏴🏴🏴🇮🇪🇺🇸⛽️🛢️⚙️🧰💪 |
11th Nov 2019 12:44pm |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6605 |
I assume the top one is the new one? Looks like a cheap pattern part to me 1988 90 Td5 NAS soft top
2015 D90 XS SW |
11th Nov 2019 12:49pm |
Housey_d444 Member Since: 27 Apr 2013 Location: Kidderminster Posts: 32 |
Yes thanks didn’t think of it being wrong way but it was in the right way.
Top pic is the new one. Do you think cheap sensor could be the issue? |
11th Nov 2019 12:50pm |
Scotm Member Since: 28 Feb 2014 Location: Aberdeenshire Posts: 666 |
Have you checked the intercooler itself - they do split also.
11th Nov 2019 12:58pm |
I’ve not had the intercooler out. I wasn’t really sure the best way to check it? I’m not a defender engineer really.
11th Nov 2019 12:59pm |
Rosco Member Since: 03 Dec 2010 Location: Burntwood Posts: 1833 |
Had the same issue with mine. Found as long as I kept the turbo off boost I could drive round the problem, as a short term get me home fix, but it got progessively worse.
The end cap for the intercooler had seperated and was audible as a hissing sound, but visually you'd never see it until you've got the cooling pack off 2007 - Stornoway Grey 90 XS SW - Gone 2002 - Black Discovery II - Gone 2014 - Montalcino Red 110 XS SW |
11th Nov 2019 1:43pm |
Take the grill off and look for something like this:
Click image to enlarge |
11th Nov 2019 2:12pm |
Not the best photo but found a split in the intercooler as you can see.
Any advice on removing the intercooler please. I have air con fitted. Any pics would also be a massive help. Thanks Click image to enlarge |
11th Nov 2019 2:42pm |
Not the best photo, but with assistance from my brother, we managed to remove the intercooler without disconnecting either the radiator or the air con rad.
Click image to enlarge The cooling pack is mounted on studs fitted into the wings (which is great when it went down the assembly line and they fitted the wings after everything else, but not really maintenance friendly) which once removed the whole lot is movable within the confines of the attached hoses. Most difficult part was getting the boost hoses back on afterwards 2007 - Stornoway Grey 90 XS SW - Gone 2002 - Black Discovery II - Gone 2014 - Montalcino Red 110 XS SW |
11th Nov 2019 3:33pm |
Steve R Member Since: 13 Jun 2012 Location: Leamington Spa & Walton-on-the-Naze Posts: 166 |
I have exactly the same problem!
Puma 2.2, P0101 fault code and 'limp mode'. The key thing, after lots of experimenting, is that it comes on regularly when lifting off the throttle after accelerating under load and spinning the turbo up. It's on again within a couple of miles after clearing the code. No obvious change in noise from the engine. So far I have: Cleaned the MAF sensor (with proper cleaner) - no improvement Checked the sensor wiring - all looks ok, but I've kind of ruled this out because it's triggered by driving style rather than intermittently. Checked the intercooler and hoses carefully - no obvious holes/splits in the hoses, the clamps are tight and the intercooler end caps look to be fine. Any suggestions as to what to eliminate next would be much appreciated - I can see me chucking hundreds at this problem changing parts with no guarantee of a fix! Please help! Cheers, Steve. |
4th Mar 2020 8:20pm |
Joe the Plumber Member Since: 18 Dec 2013 Location: Midlands Posts: 907 |
Have you checked the short 'L' shaped hose low down on the left side of the engine? When I fitted my BAS intercooler and hoses, that was the most flimsy feeling original one, and naturally, it's also hugely entertaining to swap (the skin grafts have just about healed after a year....)
4th Mar 2020 9:10pm |
Ah, no I haven't! Good suggestion, thank you, I'll take a look. Must be a pig to change as I didn't even spot it! Cheers.
4th Mar 2020 9:26pm |
For the sake of finding the problem, I hope it IS that one, but it's certainly awkward. I managed to change mine in about an hour (for one of the BAS ones - much more robust). There's links in my post a little way down this topic:
https://www.defender2.net/forum/topic56229.html |
5th Mar 2020 6:55am |
Thanks again. Had a look last night and it looks fine, but will check again in daylight Just to be sure. Cheers.
After that, is there anything on the turbo which could be sticking and causing the same symptoms on lift-off? |
5th Mar 2020 7:57am |
