Home > Puma (Tdci) > Limp mode P0101 code help please
Housey_d444
2000 Defender 90 Td5 CSW Alveston Red
Hi all. I have searched the internet with regard to my fault and not really succeeding so can anyone assist please?
I have a 2015 2.2
Driving last week it went to limp mode. If you switch of and restarts it drove for about 7 miles before going back to limp mode. The engine light was on the dash.
Picked up a cheap diognostics and shows the P0101 code only as is the issue.
Have changed the air filter and also a new MAF censor. Although they say it’s the correct one the sensor part is in a different place to the other. Would this make a difference?
Had cleared the fault and still got the same issue.
Checked the intercooler hoses and all look ok but still got the same issue.
If you reset it pretty much after a mile or two it’s back on
Attached are pic of the two censors.
Anyone else any ideas as know Landrover will be charging the earth to start checking it.
Many thanks
Scott
Post #801755 11th Nov 2019 12:39pm
Did you ensure it was fitted with the correct airflow direction as marked on the top section?
I’m sure you did, but thought I would mention it. $W33T $0U7H3RN $UG4R
Post #801757 11th Nov 2019 12:44pm
Martin
Site Admin
I assume the top one is the new one? Looks like a cheap pattern part to me Confused  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #801758 11th Nov 2019 12:49pm
Housey_d444
Yes thanks didn’t think of it being wrong way but it was in the right way.
Top pic is the new one. Do you think cheap sensor could be the issue?
Post #801760 11th Nov 2019 12:50pm
Scotm
Scotland 2012 Defender 110 Puma 2.2 SW Orkney Grey
Have you checked the intercooler itself - they do split also.
Post #801763 11th Nov 2019 12:58pm
Housey_d444
I’ve not had the intercooler out. I wasn’t really sure the best way to check it? I’m not a defender engineer really.
Post #801764 11th Nov 2019 12:59pm
Rosco
United Kingdom 2015 Defender 110 Puma 2.2 XS CSW Montalcino Red
Had the same issue with mine. Found as long as I kept the turbo off boost I could drive round the problem, as a short term get me home fix, but it got progessively worse.
The end cap for the intercooler had seperated and was audible as a hissing sound, but visually you'd never see it until you've got the cooling pack off 2007 - Stornoway Grey 90 XS SW - Gone
2002 - Black Discovery II - Gone
2014 - Montalcino Red 110 XS SW
Post #801770 11th Nov 2019 1:43pm
Scotm
Take the grill off and look for something like this:
Post #801774 11th Nov 2019 2:12pm
Housey_d444
Not the best photo but found a split in the intercooler as you can see.
Any advice on removing the intercooler please. I have air con fitted.
Any pics would also be a massive help.
Thanks
Post #801777 11th Nov 2019 2:42pm
Rosco
Not the best photo, but with assistance from my brother, we managed to remove the intercooler without disconnecting either the radiator or the air con rad.
The cooling pack is mounted on studs fitted into the wings (which is great when it went down the assembly line and they fitted the wings after everything else, but not really maintenance friendly) which once removed the whole lot is movable within the confines of the attached hoses.
Most difficult part was getting the boost hoses back on afterwards 2007 - Stornoway Grey 90 XS SW - Gone
Post #801781 11th Nov 2019 3:33pm
Steve R
2013 Defender 110 Puma 2.2 USW Keswick Green
I have exactly the same problem!
Puma 2.2, P0101 fault code and 'limp mode'.
The key thing, after lots of experimenting, is that it comes on regularly when lifting off the throttle after accelerating under load and spinning the turbo up. It's on again within a couple of miles after clearing the code. No obvious change in noise from the engine.
So far I have:
Cleaned the MAF sensor (with proper cleaner) - no improvement
Checked the sensor wiring - all looks ok, but I've kind of ruled this out because it's triggered by driving style rather than intermittently.
Checked the intercooler and hoses carefully - no obvious holes/splits in the hoses, the clamps are tight and the intercooler end caps look to be fine.
Any suggestions as to what to eliminate next would be much appreciated - I can see me chucking hundreds at this problem changing parts with no guarantee of a fix!
Please help! Crying or Very sad
Cheers,
Steve.
Post #818189 4th Mar 2020 8:20pm
Joe the Plumber
2014 Defender 110 Puma 2.2 HT Fuji White
Have you checked the short 'L' shaped hose low down on the left side of the engine? When I fitted my BAS intercooler and hoses, that was the most flimsy feeling original one, and naturally, it's also hugely entertaining to swap (the skin grafts have just about healed after a year....)
Post #818205 4th Mar 2020 9:10pm
Steve R
Ah, no I haven't! Good suggestion, thank you, I'll take a look. Must be a pig to change as I didn't even spot it! Cheers.
Post #818214 4th Mar 2020 9:26pm
Joe the Plumber
For the sake of finding the problem, I hope it IS that one, but it's certainly awkward. I managed to change mine in about an hour (for one of the BAS ones - much more robust). There's links in my post a little way down this topic:
https://www.defender2.net/forum/topic56229.html
Post #818233 5th Mar 2020 6:55am
Steve R
Thanks again. Had a look last night and it looks fine, but will check again in daylight Just to be sure. Cheers.
After that, is there anything on the turbo which could be sticking and causing the same symptoms on lift-off?
Post #818239 5th Mar 2020 7:57am
