Home > My Defender > Tonga green TD5
Page 4 of 8 <12345678>
grafty99
Looks great Thumbs Up
Glad to have helped you spend your money Laughing 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #806541 16th Dec 2019 10:34pm
L110CDL
I'm starting to like this one, nice look with the new rims and tyres Thumbs Up
But, i think you should spend a bit more and get the black nuts ( imo ) Question
That is still on my list to do is visit C & M sometime Very Happy 1996 Golf Blue 300Tdi 110 Pick up.
Keeper.
Clayton.
Post #806673 17th Dec 2019 8:11pm
Greeny
Cheers Clayton and Grafty!
Black wheel nuts will be on their way soon. Just didn't get round to it. Currently prepping the car as I have got it booked in for a full dinitrol treatment at the start of January. Debating whether or not to get the outside of the cross member treated with dinitrol at the same time along with the tow pack as it would save me time and money. But I do like the look of the painted rear cross member currently. Instagram - @Land_Rover_Defender
Post #807149 21st Dec 2019 11:32am
Greeny
So today consisted of stripping the rear mat out and giving it a good clean. Removing the seat belts was a pain due to the bolts underneath. Removed the dog guard also, gonna decide if I want this or not, I think its a good addition and is so easy to put in.
The rear mat is tired and old, so if anyone wants this then please make me an offer on it, it has some holes drilled into it where things have been previously. I will be replacing it, DM me if you want it.
Rear bulkhead bar to go in soon also!
Post #807234 22nd Dec 2019 4:45pm
L110CDL
Good news on the black nuts Greeny Thumbs Up 1996 Golf Blue 300Tdi 110 Pick up.
Keeper.
Clayton.
Post #807403 23rd Dec 2019 8:50pm
Greeny
Been busy this weekend with the TD5. EGR deleted and replaced with the bypass kit. New injector harness and tappets adjusted Very Happy
Spent today stripping out the interior and cleaning everything! I am probably being fussy but I do like a clean car, especially when it has got someone else's dog hair in it Rolling with laughter
Who doesn't like a clean battery box?
Post #807979 29th Dec 2019 5:44pm
L110CDL
Good being fussy there Greeny, i would have done the same as you with a good thorough clean Wink 1996 Golf Blue 300Tdi 110 Pick up.
Keeper.
Clayton.
Post #808150 30th Dec 2019 8:58pm
Sulisuli
Nice attention to detail Greeny Thumbs Up 2015 HT XS 90
2008 SVX 90
2000 XS TD5 90
Post #808156 30th Dec 2019 9:18pm
Greeny
Cheers guys! Will clean the back out and then stuck some sound proofing down on the back (cheers Grafty for the tip!) along with a genuine load mat Very Happy Instagram - @Land_Rover_Defender
Post #808171 30th Dec 2019 10:11pm
Greeny
Update on the Tonga Td5.
Done a fair bit of work on the car over the last month. I took the car to SouthWest Rustproofing to have the chassis sprayed in Dinitrol. Can't recommend them enough, they did a fantastic job. The old waxoyl that was on the car was a mess and they prepped the car by removing all of this properly to then give a good coating of dinitrol (see photos before and after). To my surprise I needed a new rear crossmember which was annoying, the old waxoyl was hiding a few holes on the underside and I am now glad that it has been replaced properly and treated with dinitrol (cant be sure what is hiding beneath nasty waxoyl!). The chassis now looks like new. I had a new fuel tank guard, brake pipes and some other bits which were old. So that is the chassis sorted for a good few years! I will be returning to SouthWest for an annual inspection and top up.
Discovered that I needed a new exhaust. I was planning to get a new one anyway because I wanted a straight through so this was just an excuse to do it now. I opted for a full stainless Twisted Automotive pipe. Removed the gearbox crossmember easily, with the bolts coming off no problem and there being no rusted on the chassis rails which was good news! Cut the old exhaust off and then fitted up the Twisted one. No issues with fitment, it was a perfect match. All stainless bolts used on the exhaust and stainless bolts on the gearbox crossmember. The exhaust sounds fantastic and is more responsive.
Few body bits to sort out next, I have just finished spraying the wheel carrier and tow pack. I will be spraying the crossmember in Tonga green so thats next on the list. Lots to do still! See photos below.
Post #814355 9th Feb 2020 5:25pm
Co1
My you have been busy! Which product did you use for the under seal?
Post #814372 9th Feb 2020 6:10pm
Greeny
The chassis has been treated with Dinitrol. First it was steam cleaned, all the old waxoyl removed with tools etc. It is then sprayed with Dinitrol rust converter all over. The inside of the chassis, doors and bulkhead are sprayed with Dinitrol wax, the outside of the chassis is sprayed with Dinitrol 4941 and then Dinitrol stone chip 445 is used on areas which need a harder coating like the tow pack and arches etc. Dinitrol is a great product, really happy with the results, much better than waxoyl! Instagram - @Land_Rover_Defender
Post #814375 9th Feb 2020 6:16pm
Sulisuli
Very tidy work, who made the exhaust? Looks nice workmanship Thumbs Up 2015 HT XS 90
2008 SVX 90
2000 XS TD5 90
Post #814395 9th Feb 2020 7:20pm
Greeny
SuliSuli the exhaust is from Twisted Automotive Instagram - @Land_Rover_Defender
Post #814401 9th Feb 2020 7:40pm
Harry.O
United Kingdom 1989 Defender 90 300 Tdi ST Nato Green
Good work Greeny! What are your thoughts on the exhaust? How does it sound? I've currently got a TD5 with a straight through mid-pipe and decat front section but it's starting to crack/rot etc so looking for a more robust solution and can't decide between Twisted and Alive offerings. 2005 Td5 110 Hardtop
1989 300Tdi 90 Soft top
1992 200Tdi 90 Truck cab with Land Cruiser axles
Post #814441 10th Feb 2020 6:50am
