Home > Maintenance & Modifications > looking for 110 rally suspension set-up |
noriega Member Since: 15 Apr 2015 Location: Lugano Posts: 7 |
As you are in italy, i can recommend: https://www.oramsospensioni.it/
Otherwise: https://re-suspension.de/ cheers, mike |
13th Aug 2019 12:13pm |
Cippo Member Since: 24 Oct 2012 Location: Florence Posts: 19 |
Thank you.
this is the result I would like to get: https://youtu.be/ip2LmqglznM |
13th Aug 2019 2:53pm |
Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6300 |
I'm no expert in this but suspect you may need more than new shocks and wheel spacers to get a 110 to handle in the same way?
good luck |
13th Aug 2019 2:59pm |
Sure I know the money will (maybe) do the magic...!!! or not?
13th Aug 2019 3:03pm |
90 Dreamer Member Since: 13 Jul 2019 Location: Oop North Posts: 2169 |
surely speaking to the likes of Bowler, et al who have the background and experience of this type of modification would be the first step??
13th Aug 2019 3:29pm |
sure something like this: https://www.bowlermotorsport.com/product/rally-suspension-system/
hard for me to fid out if somebody here in the forum has installed a similar kit on a 110... |
13th Aug 2019 3:30pm |
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4217 |
Those trophy trucks are great over the bumps and in the air, but they have comedy handling on tarmac, three wheeling around corners. See video I would suggest such a set up is not ideal if you aren't leaping off dunes at top speed all day.
2007 110 TDCi Station Wagon XS |
13th Aug 2019 3:54pm |
impossible without very serious modifications; you would need to aprox. double the length of the dampers...
easier and cheaper to just buy a bowler bulldog (which just looks like a defender but has a space frame in order to get the required setup) Click image to enlarge |
14th Aug 2019 11:51am |
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7907 |
I still want to see the full video of that Bulldog jump. It gets some serious air but the video I saw cuts off just as it lands, so can't really see it it landed safely? James
MY2012 110 2.2TDCi XS SW Orkney Grey - http://www.defender2.net/forum/topic43410.html MY1990 110 200TDi SW beautifully faded Portofino Red - https://www.defender2.net/forum/post743641.html#743641 MY1984 90 V8 Slate Grey - https://www.defender2.net/forum/post744557.html#744557 Instagram @suffolk_rovers |
14th Aug 2019 12:55pm |
Well i do not drive my defender so fast in real life thus I do believe the way the are cornering will be more the enoungh for me to stay safe and sound! |
14th Aug 2019 2:09pm |
I have to say this looks like entertaining stuff. do they run 2.4 tdci's - mapped of course?
14th Aug 2019 3:54pm |
no they dont but this runs a Td5
https://youtu.be/T1RhZK6ckFs |
14th Aug 2019 3:59pm |
