![]() | Home > Maintenance & Modifications > looking for 110 rally suspension set-up |
noriega Member Since: 15 Apr 2015 Location: Lugano Posts: 7 ![]() |
As you are in italy, i can recommend: https://www.oramsospensioni.it/
Otherwise: https://re-suspension.de/ cheers, mike |
Cippo Member Since: 24 Oct 2012 Location: Florence Posts: 19 ![]() ![]() ![]() |
Thank you.
this is the result I would like to get: https://youtu.be/ip2LmqglznM |
Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6328 ![]() ![]() ![]() |
I'm no expert in this but suspect you may need more than new shocks and wheel spacers to get a 110 to handle in the same way?
good luck ![]() |
Sure I know
90 Dreamer Member Since: 13 Jul 2019 Location: Oop North Posts: 2231 ![]() ![]() ![]() |
surely speaking to the likes of Bowler, et al who have the background and experience of this type of modification would be the first step??
sure something like this: https://www.bowlermotorsport.com/product/rally-suspension-system/
hard for me to fid out if somebody here in the forum has installed a similar kit on a 110... |
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4262 ![]() ![]() ![]() |
Those trophy trucks are great over the bumps and in the air, but they have comedy handling on tarmac, three wheeling around corners. See video I would suggest such a set up is not ideal if you aren't leaping off dunes at top speed all day.
2007 110 TDCi Station Wagon XS |
impossible without very serious modifications; you would need to aprox. double the length of the dampers...
easier and cheaper to just buy a bowler bulldog (which just looks like a defender but has a space frame in order to get the required setup) ![]() Click image to enlarge |
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7918 ![]() ![]() ![]() |
I still want to see the full video of that Bulldog jump. It gets some serious air but the video I saw cuts off just as it lands, so can't really see it it landed safely? James
Well i do not drive my defender so fast in real life thus I do believe the way the are cornering will be more the enoungh for me to stay safe and sound! |
I have to say this looks like entertaining stuff. do they run 2.4 tdci's - mapped of course?
no they dont but this runs a Td5
![]() https://youtu.be/T1RhZK6ckFs |
