![]() | Home > Puma (Tdci) > water puddles |
NinetyTD4 Member Since: 22 Apr 2011 Location: North Posts: 397 ![]() ![]() ![]() |
Check the front window seal, if thre is a leak it will be collected under the window and goes to bothq sides dripping on the footwells - known issue ...
check the top front corners of the door seals,they can leak from there,adjusting the stricker should cure it if they are the culprit 2.4 90 XS
mse Member Since: 06 Apr 2008 Location: UK Posts: 5059 ![]() ![]() ![]() |
One thing for certain...there are a few leak points on a defender!! Mike
flinty99 Member Since: 28 Jun 2010 Location: Durham Posts: 41 ![]() ![]() |
Mine has a leak from the passenger door seal and I think one from the rear door.
At least on my Defender I don't have a sun roof so no chance there ![]() |
