Home > Puma (Tdci) > water puddles |
NinetyTD4 Member Since: 22 Apr 2011 Location: North Posts: 397 |
Check the front window seal, if thre is a leak it will be collected under the window and goes to bothq sides dripping on the footwells - known issue ...
31st May 2011 4:02pm |
Grockle Member Since: 24 Nov 2008 Location: Peak District National Park Posts: 2266 |
check the top front corners of the door seals,they can leak from there,adjusting the stricker should cure it if they are the culprit 2.4 90 XS
31st May 2011 5:22pm |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5034 |
One thing for certain...there are a few leak points on a defender!! Mike
31st May 2011 11:10pm |
flinty99 Member Since: 28 Jun 2010 Location: Durham Posts: 41 |
Mine has a leak from the passenger door seal and I think one from the rear door.
At least on my Defender I don't have a sun roof so no chance there |
31st May 2011 11:32pm |
