Home > Puma (Tdci) > water puddles
galawaygreen
2010 Defender 90 Puma 2.4 XS CSW Galway Green
water puddles
hi went out to my landrover this morning found two puddles of water in both front footwells, any idea where these come from had a look and found drips coming from bulkheads but cannot find entry point any ideas?
Post #73588 31st May 2011 1:24pm
NinetyTD4
Wales 2012 Defender 90 Other SW Keswick Green
Check the front window seal, if thre is a leak it will be collected under the window and goes to bothq sides dripping on the footwells - known issue ...
Post #73594 31st May 2011 3:02pm
Grockle
check the top front corners of the door seals,they can leak from there,adjusting the stricker should cure it if they are the culprit 2.4 90 XS
1968 1/32 scale Britains 109 Pick up.
Post #73603 31st May 2011 4:22pm
mse
One thing for certain...there are a few leak points on a defender!! Mike
Post #73687 31st May 2011 10:10pm
flinty99
2007 Defender 110 Puma 2.4 XS CSW Stornoway Grey
Mine has a leak from the passenger door seal and I think one from the rear door.
At least on my Defender I don't have a sun roof so no chance there Laughing
Post #73688 31st May 2011 10:32pm
