Home > Puma (Tdci) > Towball question for caravanners
rossy
hi,
like most caravans nowadays ours has an Alko stabiliser which requires an extended neck towball.
I have heard that it can be tricky to hitch up to the Puma because of the spare wheel getting in the way of the stabiliser handle. Some people open the back door when hitching up but then have to remove the jockey wheel in order to close it again or so I've heard.
There are towball spacers available in sizes ranging from 1/2" to 1.5" at sites such as Autow.com with the corresponding extended bolts. Would using one of these help to give enough clearance ? Or how else do you hitch up easily.I'd appreciate any advice
Post #73546 31st May 2011 5:40am
Barry
Hi Rossy,
Only done this once so far but this is how i did it
Reverse onto the hitch with the Alko handle down , once in place open the rear door enough to lift alko handle and then hitch as normal. Close rear door.
I will be off again this weekend but I don't expect any problems .
Cheers 2011 Defender XS 110 Station Wagon - Rejected
2008 Discovery 3 XS Auto (Gone)
1997 Discovery ES Auto 300TDI (Traded in on a flat bed)
Post #73556 31st May 2011 8:11am
rossy
hey that sounds easy. Thanks Barry and enjoy the weekend Very Happy
Post #73622 31st May 2011 6:30pm
damon62
England 2010 Defender 90 Puma 2.4 XS CSW Santorini Black
hello all
have just bought a 90 puma and am trying to buy a fleetwood twin axle caravan can anyone tell me if my car is capable of towing this size of van
thanks
Post #75709 13th Jun 2011 9:09pm
Barry
Hi
I asked the same question all be it a 110 , hope this links works for you and is useful
http://www.defender2.net/forum/topic6480.h...fender+tow
Post #75715 13th Jun 2011 9:30pm
damon62
Hi Barry
Thanks for this my 90 is a bit lighter than your 110 but i think it will be fine had a remap from Pete at bell autos plus intercooler and new exhaust power is up dramatically so am not worried about that bit just the weight
issue.
anyway
cheers
damon
Post #75717 13th Jun 2011 9:42pm
amondeggs
United Kingdom 1999 Defender 90 Td5 HT Woodcote Green
HI I had the same problem of clearing the spare wheel until I bought one of these
http://shop.al-ko.co.uk/products/4x4-retro...andle.html
You can get them pretty cheap on certain online auction sites.
You use the removable handle to engage and disengage the stabiliser and remove it when towing,
hope this helps Thumbs Up
Post #75726 13th Jun 2011 10:10pm
mse
damon62 wrote:
hello all
thanks
There is no towing difference between a 90, 110 and 130 or a RRS, FFRR, Disco - all can tow 3.5t (and tow them well)
Land Rover are the best towing machines and you will have no issues - except it does look funny,
Funnier still as a Censored on my makes trailer that if his 110 was on the trailer it couldnt have towed it but the land rovers can Mike
Post #75814 14th Jun 2011 4:50pm
Lorryman100
damon62 wrote:
hello all
thanks
Yes, without even breaking sweat Whistle
Post #75820 14th Jun 2011 5:22pm
rossy
thanks amondeggs. I presume the standard red plastic Alko handle comes off and stays off for good with this handy little gadget
Post #75903 14th Jun 2011 9:41pm
amondeggs
Yes when you buy the removable handle it comes with the tool to remove the existing handle. Once you have removed it then you snap the removable one only when you either apply for disengage the stabiliser. Works well for me on a 90 td5. Thumbs Up
Post #76101 15th Jun 2011 7:57pm
damon62
Hi All
One other thing what is the ideal tow bar height before hitching up caravan mine seems quite high at the minute.
Damon
Post #76269 16th Jun 2011 4:25pm
Barry
If it is a twin Axle then it needs to be level otherwise I understand it can cause problems with tyre overhearing , blowouts etc... not to mention the extra W&T , as one axle or the other takes the load.
Also , nose weight should be right.
Post #76273 16th Jun 2011 4:39pm
Lorryman100
With an OEM tow pack I use the bottom mounting holes for the alko towball, this allows a level tow with my twin axle Thumbs Up I am about to change this setup though by fitting a dixon bate alko jaw and pin hitch to give me a safe recovery option on the rear of the landy.
Post #76344 16th Jun 2011 10:58pm
