Home > Puma (Tdci) > Towball question for caravanners |
Barry Member Since: 26 Apr 2011 Location: North East Posts: 137 |
Hi Rossy,
Only done this once so far but this is how i did it Reverse onto the hitch with the Alko handle down , once in place open the rear door enough to lift alko handle and then hitch as normal. Close rear door. I will be off again this weekend but I don't expect any problems . Cheers 2011 Defender XS 110 Station Wagon - Rejected 2008 Discovery 3 XS Auto (Gone) 1997 Discovery ES Auto 300TDI (Traded in on a flat bed) |
31st May 2011 8:11am |
rossy Member Since: 29 Nov 2010 Location: Co. Roscommon Posts: 1296 |
hey that sounds easy. Thanks Barry and enjoy the weekend
31st May 2011 6:30pm |
damon62 Member Since: 07 May 2011 Location: north west Posts: 6 |
hello all
have just bought a 90 puma and am trying to buy a fleetwood twin axle caravan can anyone tell me if my car is capable of towing this size of van thanks |
13th Jun 2011 9:09pm |
Hi
I asked the same question all be it a 110 , hope this links works for you and is useful http://www.defender2.net/forum/topic6480.h...fender+tow Cheers 2011 Defender XS 110 Station Wagon - Rejected 2008 Discovery 3 XS Auto (Gone) 1997 Discovery ES Auto 300TDI (Traded in on a flat bed) |
13th Jun 2011 9:30pm |
Hi Barry
Thanks for this my 90 is a bit lighter than your 110 but i think it will be fine had a remap from Pete at bell autos plus intercooler and new exhaust power is up dramatically so am not worried about that bit just the weight issue. anyway cheers damon |
13th Jun 2011 9:42pm |
amondeggs Member Since: 06 Mar 2011 Location: Telford Posts: 452 |
HI I had the same problem of clearing the spare wheel until I bought one of these
http://shop.al-ko.co.uk/products/4x4-retro...andle.html You can get them pretty cheap on certain online auction sites. You use the removable handle to engage and disengage the stabiliser and remove it when towing, hope this helps |
13th Jun 2011 10:10pm |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5048 |
There is no towing difference between a 90, 110 and 130 or a RRS, FFRR, Disco - all can tow 3.5t (and tow them well) Land Rover are the best towing machines and you will have no issues - except it does look funny, Funnier still as a on my makes trailer that if his 110 was on the trailer it couldnt have towed it but the land rovers can Mike |
14th Jun 2011 4:50pm |
Lorryman100 Member Since: 01 Oct 2010 Location: Here Posts: 2686 |
Yes, without even breaking sweat Click image to enlarge |
14th Jun 2011 5:22pm |
thanks amondeggs. I presume the standard red plastic Alko handle comes off and stays off for good with this handy little gadget |
14th Jun 2011 9:41pm |
Yes when you buy the removable handle it comes with the tool to remove the existing handle. Once you have removed it then you snap the removable one only when you either apply for disengage the stabiliser. Works well for me on a 90 td5.
15th Jun 2011 7:57pm |
Hi All
One other thing what is the ideal tow bar height before hitching up caravan mine seems quite high at the minute. Cheers Damon |
16th Jun 2011 4:25pm |
If it is a twin Axle then it needs to be level otherwise I understand it can cause problems with tyre overhearing , blowouts etc... not to mention the extra W&T , as one axle or the other takes the load.
Also , nose weight should be right. Cheers 2011 Defender XS 110 Station Wagon - Rejected 2008 Discovery 3 XS Auto (Gone) 1997 Discovery ES Auto 300TDI (Traded in on a flat bed) |
16th Jun 2011 4:39pm |
With an OEM tow pack I use the bottom mounting holes for the alko towball, this allows a level tow with my twin axle I am about to change this setup though by fitting a dixon bate alko jaw and pin hitch to give me a safe recovery option on the rear of the landy.
16th Jun 2011 10:58pm |
