![]() | Home > Puma (Tdci) > Colour of hydraulic clutch fluid |
Its normal. It doesn't take long to change colour as you've already noticed.
Harald Member Since: 30 May 2012 Location: Flanders Fields Posts: 81 ![]() ![]() ![]() |
THNX!!
richcl Member Since: 25 Mar 2011 Location: tewkesbury Posts: 25 ![]() ![]() |
It maybe a sign that your master cylinder rubbers are degrading / close to failing, as rubber is black.
THNX, I thought something like that myself.
But I was not sure if it would be the slave cylinder in the clutch housing, or the master cylinder attached to the clutch pedal. If I remember correctly the master cylinder is changed a few years ago(by a none OEM one I guess). Maybe the quality of the rubber cups used in that (non original) cylinder is not as good as the ones in an original LR or OEM cylinder............? |
kaney Member Since: 01 Oct 2018 Location: Bolton Posts: 232 ![]() ![]() ![]() |
Just had the Master cylinder replaced as the pedal was soft in the morning but after running the engine for a while firmed up some days it stayed firm for a few days then went soft again (no it did'nt run out of little blue tablets) any way when i looked at the old original one after 176000 miles they took out it was proper black gunk behind the rubber seal and after having it back for a week or so and doing a 100 plus miles its been fine
I will have a look at the master cylinder.
The rubber from the cup must be different from the rubber used in the brake master cylinder as the brake fluid keeps his (original) colour. |
Pilgrimmick Member Since: 16 Nov 2015 Location: Highlands Posts: 582 ![]() ![]() |
Not changed mine in ten years and only now going dark. Let’s be honest here it is not worked hard! 80" 1948
Lightweight V8 Bowler Tomcat 130 Station wagon 90 300tdi (Santana PS10 pick up) Range Rover L322 (Ful fat) |
Timcat Member Since: 20 Jul 2016 Location: Rugby at the moment Posts: 1025 ![]() ![]() ![]() |
Changed the clutch on ours & it wouldn’t bleed 100% plus the fluid was black a day after changing it. New genuine master cylinder & the clutch bled no problem and the fluid is clear..
Thanks to all who replied.
I ordered a new master cylinder last week. Hope to get it this week. |
