Home > Puma (Tdci) > Colour of hydraulic clutch fluid
Harald
Belgium 2010 Defender 90 Puma 2.4 Fire LE Vesuvius Orange
My hydraulic clutch fluid becomes (fast) black after changing the fluid.
Is this normal, of should I be worried?
Post #780475 7th Jul 2019 11:13am
williamthedog
Its normal. It doesn't take long to change colour as you've already noticed. Thumbs Up
Post #780477 7th Jul 2019 11:16am
Harald
THNX!!
Post #780481 7th Jul 2019 11:39am
richcl
It maybe a sign that your master cylinder rubbers are degrading / close to failing, as rubber is black.
Post #780485 7th Jul 2019 12:29pm
Harald
THNX, I thought something like that myself.
But I was not sure if it would be the slave cylinder in the clutch housing, or the master cylinder attached to the clutch pedal.
If I remember correctly the master cylinder is changed a few years ago(by a none OEM one I guess).
Maybe the quality of the rubber cups used in that (non original) cylinder is not as good as the ones in an original LR or OEM cylinder............?
Post #780505 7th Jul 2019 2:31pm
kaney
United Kingdom 2005 Defender 90 Td5 CSW Epsom Green
Just had the Master cylinder replaced as the pedal was soft in the morning but after running the engine for a while firmed up some days it stayed firm for a few days then went soft again (no it did'nt run out of little blue tablets) any way when i looked at the old original one after 176000 miles they took out it was proper black gunk behind the rubber seal and after having it back for a week or so and doing a 100 plus miles its been fine
Post #780534 7th Jul 2019 5:41pm
Harald
I will have a look at the master cylinder.
The rubber from the cup must be different from the rubber used in the brake master cylinder as the brake fluid keeps his (original) colour.
Post #780566 7th Jul 2019 8:26pm
Pilgrimmick
Not changed mine in ten years and only now going dark. Let’s be honest here it is not worked hard! 80" 1948
Lightweight V8
Bowler Tomcat
130 Station wagon
90 300tdi
(Santana PS10 pick up)
Range Rover L322 (Ful fat)
Post #780568 7th Jul 2019 8:54pm
Timcat
United Kingdom 2012 Defender 110 Puma 2.2 SW Indus Silver
Changed the clutch on ours & it wouldn’t bleed 100% plus the fluid was black a day after changing it. New genuine master cylinder & the clutch bled no problem and the fluid is clear..
Post #781522 15th Jul 2019 6:42am
Harald
Thanks to all who replied.
I ordered a new master cylinder last week.
Hope to get it this week.
Post #781535 15th Jul 2019 8:03am
