Home > Td5 > gear selector housing removal in situ
kevinf
Hi all I need to remove the gear selector housing from my r380 gear box due to it jamming in gear
can this be done with out removing the gear box, and if so what's the procedure, I'm hoping its the grub screw that's come loose I've already removed the gear lever turret and the transfer box selector lever housing, but it still jams in 5th gear (when I pull it out of 5th it doesn't find the gate to allow the gear lever to move across)
cheers in anticipation kevin
Post #780021 3rd Jul 2019 11:28am
4RF RDS
It can be totally done in situ. Thirteen screws on the tunnel cover, two 10 mm on the parking brake lever and you will have complete access. Don’t need to remove any of those to check the grub screw though, just pull up the shifter boot and remove the knobs, undo the shift lever and remove the turret. You’ll have full access.
Good luck 2010 Range Rover MkIII Autobiography Super Charged (Idris)
1967 MGB GT
H. L. Mencken (1880 - 1956)
Post #780086 4th Jul 2019 12:30am
kevinf
hi thanks for the reply got the housing off last night, also had to remove the transfer box mountings to allow the transmission to drop down to allow the selector fork to clear ! I had previously removed the turret and checked the front grub screw, total waist of time and effort as the grub screw was tight and the gear selector was tight and notchy with the housing removed and stayed tight until I removed the rear prop and hand brake assembly (X brake) then the selector shaft became free so I put the selector housing back on but still cant select reverse !
scratching head now is it gear box, transfer box Sad
cheers kevin
Post #780129 4th Jul 2019 11:27am
4RF RDS
Have you set the bias springs properly? That can affect finding reverse. If so its in the gearbox not the t- case.
Good luck Thumbs Up 2010 Range Rover MkIII Autobiography Super Charged (Idris)
1967 MGB GT
Post #780149 4th Jul 2019 1:24pm
