Home > Technical > 300tdi oil light issue
Nadine90
Wales 1986 Defender 90 300 Tdi CSW Fuji White
300 tdi Issue
I have a 300 tdi and had to do the head gasket. so put a new head fromer turners and new head gasket, changed that and then found the oil cooler was leaking into the radiator, so we changed out with new radiator.
Now the oil light is staying on and i will not run it just encase i cause any damage.
i have checked the oil sensor plug and taken out and cleaned, but still oil light will not turn of when turned over.
what should i be looking for next ? Big Cry Big Cry
Post #778665 23rd Jun 2019 7:36pm
jfh
South Africa 2007 Defender 110 300 Tdi SW Chawton White
How long has it turned over. (Idled)?
The engines I've rebuild, the first few swings of the starter, 1-2 seconds at a time, there is no pressure.
I keep on "pulsing" the starter until I get pressure.( Swing and switch off)
If switch is okay and you don't get pressure after about 5 tries, I would go deeper.
Post #778970 25th Jun 2019 5:25pm
Nadine90
I only turned key then switched off again when light would go out.
Post #778985 25th Jun 2019 6:44pm
jfh
Try a few more times but only for 2 seconds at a time.
I think one engine I did took 5 tries. If you aren't successful after that replace the switch.
Post #779031 26th Jun 2019 5:31am
Nadine90
all sorted now. It was a cheap sensor, replaced with Gen and went out straight away. lesson learnt don't by Bearmach crap again.
Post #781375 13th Jul 2019 6:55pm
