![]() | Home > Technical > 300tdi oil light issue |
jfh Member Since: 08 Jan 2014 Location: West Coast Posts: 364 ![]() ![]() ![]() |
How long has it turned over. (Idled)?
The engines I've rebuild, the first few swings of the starter, 1-2 seconds at a time, there is no pressure. I keep on "pulsing" the starter until I get pressure.( Swing and switch off) If switch is okay and you don't get pressure after about 5 tries, I would go deeper. |
Nadine90 Member Since: 07 Jan 2018 Location: CAERPHILLY Posts: 49 ![]() ![]() ![]() |
I only turned key then switched off again when light would go out.
Try a few more times but only for 2 seconds at a time.
I think one engine I did took 5 tries. If you aren't successful after that replace the switch. |
all sorted now. It was a cheap sensor, replaced with Gen and went out straight away. lesson learnt don't by Bearmach crap again.
