Home > In Car Electronics > Am/FM aerial
itolond
Singapore 1997 Defender 110 300 Tdi SW Alpine White
Am/FM aerial
Hi forum,
What aerials are you fitting to your landys?
Seeking ideas in an external aerial which is also ok for off road bumps.
Can I use a UHF cb type whip for the radio, I was considering for future use and to use on the from wing as a bit of a height clearance guide ( roll cage and roof tent)
Any guides welcome
Post #778349 21st Jun 2019 4:49am
V8Simon
United Kingdom 1985 Defender 90 V8 Petrol SW Auto Arles Blue
I've had one of these on mine for 12 months now. its DAB / FM but went for it as its small and does what it is supposed to do.
https://www.dynamicsounds.co.uk/jvc-hal3-c...erial.html
Post #778372 21st Jun 2019 8:43am
kmac
If you want to use the same aerial for CB and Radio you will need a splitter - something like this:
https://www.thunderpole.co.uk/switches-fil...itter.html - mixed reviews on signal quality
For radio only - this is good: Blaupunkt Autoflex aerial - It is amplified so will need battery connection
Post #778377 21st Jun 2019 9:50am
itolond
Blaupunkt Autoflex aerial Look
Pretty pricey, worth it?
Post #778478 22nd Jun 2019 6:40am
geobloke
Have to confess I haven't had an external aerial for many years now. Initially because I had to replace the external aerial 4 times in a month because some silly sod had a habit of breaking them off at night when parked up.
Have had one of these amplified internal aerials fitted in one of the alpine windows since then and it has worked brilliantly;
https://www.amazon.co.uk/d/Home-Garden-Sto...B001AIPF06
Post #779047 26th Jun 2019 8:41am
kmac
Works well. However £7 ebay aerial works just as well. Will try and find the link but on this forum somewhere
Edit - Link found:
https://www.ebay.co.uk/itm/250559708597?_t...EBIDX%3AIT
Price increase since 2014 but still under a tenner
from this thread
https://www.defender2.net/forum/topic32181...bay+aerial
Post #779068 26th Jun 2019 10:17am
itolond
appreciated
Post #779082 26th Jun 2019 11:53am
kmac
Np - just noticed you are in Singapore.
Hope you are not ordering from UK ebay else the aerial would have travelled all the way from the far east to the UK and then back again to the far east... Laughing
Post #779209 27th Jun 2019 10:22am
