![]() | Home > Puma (Tdci) > Air box modification - Do it!! |
K.M Member Since: 28 Apr 2016 Location: Salisbury Posts: 300 ![]() ![]() ![]() |
Is that all that is involved with the modification? Removing the propeller?
I'm curious as to whether a more unrestricted air flow will actually benefit anything?
I understand the logic on an "analogue" engine but ours are now fully "digital". There's a number of air flow sensors and the standard ecu must have other set parameters including wheel speed and the like, so I just wonder if it just hits another limit, either physical or software related within the overall system? |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17600 ![]() ![]() ![]() |
Improving the induction system makes a massive difference to the performance and smooth running of the engine.
Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3698 ![]() ![]() ![]() |
When I took the diffuser out of mine there was an instant noticeable difference to how smooth the engine ran. It revved more freely and sounded much sweeter at idle.
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20613 ![]() ![]() |
I agree with the statement Blackwolf mentioned - This is what happened with mine in a real world scenario.
Removing the rain separator isn't the only thing it's the inlet to cut out in the base of the air box. You do have to be careful if you do, I used a hot knife if I remember rightly. I used to have a picture of inside the air box but I don't have it any more. Basically as you look in the air box you'll see at the bottom the large inlet hole. You need to remove this round plastic piece inside the air box which then leads out of the air box to the left. Leaving the outer structure of the air box body only. This allows the air to come in from the left and up with less restriction rather than being in that restrictive piece in the bottom of the air box. It is definitely worth doing. ![]() ⛽️🛢️⚙️🧰💪 Last edited by custom90 on 19th Mar 2020 8:49pm. Edited 1 time in total |
Way to go, HUGE difference!
![]() Click image to enlarge ![]() Click image to enlarge |
Zed Member Since: 07 Oct 2017 Location: In the woods Posts: 3348 ![]() ![]() ![]() |
Seconded. Nuggetstuff kit makes a big difference. WARNING.
This post may contain sarcasm. |
diduan Member Since: 13 Oct 2016 Location: Central Balkan Posts: 260 ![]() ![]() |
I drove it today to the near town and back. I don't see a wow effect, but the engine performs better in low rpms. I think the "1st-2nd gear struggle" is somehow cured now and for me this is a big
![]() Jeep Wrangler YJ 1990 4.0. Front 78' Dana 60, Rear CUCV 14 bolt |
Merlin Member Since: 30 Oct 2010 Location: Newmarket Posts: 981 ![]() ![]() |
Definitely better.
JoolsB Member Since: 28 Mar 2020 Location: The North Posts: 162 ![]() ![]() ![]() |
Did mine yesterday and added the Nugget RAI adapter kit now I have some time on my hands. Mine already has a remap but it seems to pull a lot smoother below 2000 revs and just feels better somehow. Well worth it.
Planetary Member Since: 14 Jun 2020 Location: Queenstown Posts: 5 ![]() ![]() ![]() |
I did the airbox mod today and was very pleasantly surprised at the result. It is actually now very pleasant to drive, All the horrible shunting/bunny hopping has gone, and the light throttle 1-2000rpm is useable for slow speed driving.
I do understand the downside of removing the water seperator, but with a Mantec RAI and a Nugget sealed air duct on the way I think I have water ingress covered. And yes, I do consider the snorkel to be an essential piece of kit (one of our best local trails has 26 river crossings!). I'ts not there to turn it into a submarine, but that one day when you are crossing that river at a sensible depth and the wheel drops into a hole you didn't see, then it will save you. |
Bluericky Member Since: 26 Jun 2014 Location: Cornwall Posts: 647 ![]() ![]() ![]() |
Great mod and An instant difference , I fitted the Nugget Air Filter housing last week and again there’s a noticeable change in performance , with throttle response and turbo . The engine sound is noticeably different as well .
It was a lot of money and I had my doubts but am really pleased . If you do both in one go , the difference would be hugely noticeable https://www.instagram.com/hustynminepark/ |
chrisrigbywork@gmail.com Member Since: 13 Nov 2022 Location: Liverpool Posts: 1 ![]() ![]() ![]() |
Hi guys,
Ive currently got a hybrid turbo and a remap with a raised air intake snorkel with a nuggetstuff sealed air box system. At the moment currently my air box cant handle the air intake keeps coming up with change air filter as soon as i put some power down. Any ideas do i need to get rid of the nugget stuff air filter box and go back to standard any ideas would be appreciated it thanks |
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2660 ![]() ![]() ![]() |
how on earth have I not seen this mod before??? damn you, now I have to get one ![]() 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged ![]() ![]() Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
