Home > Puma (Tdci) > Glow plug faulty - replace one or all of them? |
MR_JAMES Member Since: 10 Oct 2013 Location: ESSEX Posts: 248 |
I replaced mine last year (at 7 years old) none of them were working! only one got luke warm, the rest did not.
Do them all. Twist / turn them as you pull / lever them out. 1953 80" 1987 mini city e 2011 90" |
18th May 2019 8:54pm |
Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6304 |
so with none of them working how bad did things get?
what I mean is with one not working do you even notice. if not this should be considered against the potential problems caused should it shear off while trying to remove it? |
18th May 2019 10:01pm |
mick Member Since: 08 Feb 2010 Location: Yorkshire Posts: 2109 |
All itโs not an easy job
18th May 2019 10:22pm |
Maybe a second or two slower to start in the winter but I didn't even realise. I wanted to clean the inlet manifold of muck and thought to do them at the same time as they are not expensive.
I found it easy but then am good with the spanners! 1953 80" 1987 mini city e 2011 90" |
20th May 2019 8:21pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20468 |
Shouldn't there be DTC's logged with glow plug faults? Obviously no MIL or you'd have noticed.
I thought they were on the radar so to speak with ECU monitoring. No Guts, No Glory. ๐ฌ๐ง๐ด๓ ง๓ ข๓ ฅ๓ ฎ๓ ง๓ ฟ๐ด๓ ง๓ ข๓ ท๓ ฌ๓ ณ๓ ฟ๐ด๓ ง๓ ข๓ ณ๓ ฃ๓ ด๓ ฟ๐ฎ๐ช๐บ๐ธโฝ๏ธ๐ข๏ธโ๏ธ๐งฐ๐ช |
20th May 2019 8:33pm |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2429 |
Are glow plugs really needed on moderate climates? Puma 110" SW
20th May 2019 10:39pm |
